Mild 390 build
Old 03-09-2017, 08:41 AM
yohon's Avatar
yohon
yohon is offline
Mild 390 build
Hello again yall. Im in a bit over my head here so i figured it would be a good idea to get some professional help. I got a new 390 build im wanting to slide into my daily driver (a 1973 f250 360 with a 3 on the tree and 3.7 rear dif) current plan is to slide cj valves into stock mid risers couple that to a cast iron pi intake with a 750 holly. Bump up compression up to 10 to 1 with flat tops( willing to run 93 ) slide in a hot cam ( any sudgestions?) run a msd electronic igniton kit. Stock oil pan but possibly a high flow oil pump. I have adjustable rockers and long tube truck headers. Im looking for about 400 hp and the same for torque. Thanks for helping yall.
Old 03-10-2017, 09:54 PM
Morgan Whitman's Avatar
Morgan Whitman
Morgan Whitman is offline
I'm interested in anything you all have on this as well, I just bought a '76 F150 with a 390 in it and it seems she is pouring oil out of what I think to be several places, the rest of her has only minor issues.
Right now i'm sensing an engine rebuild looming in the moderately near future, so any help will be helping more than the one guy here!! Thanks for your time!!
Old 03-10-2017, 11:46 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Welcome to FTE to both of you.
On this first page alone there are 2 or more 390 build discussions. This forum is full of them, along with threads titled "360..." that end up 390 or bigger.
Also, did you stop in at the top and read the FAQ?
Headers, 9.5 compression, 390 GT or other fine cam, 650 to 750 CFM vacuum secondary carb.
Old 03-11-2017, 05:18 PM
69cj's Avatar
69cj
69cj is offline
Why not look at the cam specs. Etc. for a 428cj. Good street motor with plenty of oomph.
Old 03-11-2017, 05:22 PM
85e150's Avatar
85e150
Isn't the 390GT the same cam?
https://www.428cobrajet.org/id-cam
Old 03-11-2017, 05:39 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
check out Lunati Voodoo series cams If you got the $$ go for the roller vesion
Old 03-14-2017, 07:15 PM
yohon's Avatar
yohon
yohon is offline
Ok thanks fokes. I did some reading and found a build similar to mine did not realize how much their was to this forum thanks for the help yall
Old 03-21-2017, 12:45 PM
jakeharp's Avatar
jakeharp
jakeharp is offline
Yep
That's very common for the FE blocks that have been running and or sitting for years.... you may just need to re-seal the whole block, which is very do-able, even with limited wrenching experience. I did mine this last fall on the weekends and its been an overall success. But first thing would be to compression test your cylinders and make sure that she doesn't need piston, rings etc.......
sworddylan
05-25-2017 03:01 PM
austin.dockter
09-30-2008 05:50 AM
Scifi266
03-07-2008 01:33 AM
Rancho*Ryda
02-07-2005 03:04 PM
BMW2
12-30-2002 06:53 AM
Quick Reply: Mild 390 build
