1966 Galaxie 390 vs 360 to 390 mini-build
Hello yall, im looking for some opinions on what i should do here. I recently purchased a 70' f100. Plan it to make it a short bed, and drop it down some and use it as a shop truck. Right now it has a 360/4 speed. Engine seems to run well, it is all stock. I was going to put the 390 crank and rods in it and go that route, but i my search for the 390 parts i came across someone with a 4 barrel 390 out of a 66 galaxie, and an auto trans for $600. Supposedly has 80k original miles on it. Should i continue with my plan to put a 390 together or get the galaxie 390? The truck is sort of a budget build, at least for the time being. Any benefits to the galaxie engine over putting the 390 together? heads any better? Rotating assembly any better? I know it should be 10.5:1 Comp which is a plus, but from my research using the 360 pistons with the 390 stuff also ups the compression to like 9.25:1. I dont know, im a little torn, i like the idea of dropping in the galaxie and putting some headers and a cam in it and call it a day, but if itll be cheaper but say 400 bucks i may just do the 360-390 deal. Curious what you all have to say. Thanks in advance!
I read once somewhere that the early 1966 "7 LITRE" Galaxys got a 427 and the later ones got a 428. Might have been Cars & Parts magazine. Ford's parts books do not reflect this however.
I know of a kid in Anchorage who brought his mom's old 4 door Mercury in to shop class to fix the oil pan. She had bought it new and it had a cammer.
Ford offered an automatic transmission in 3/4 ton 4x4s in 1968 but there is nothing in any sales brochure about it. I have the actual publication that was to be inserted in the salesman's binder telling how to order them.
Depending on the heads on the galaxy, you may have some problems bolting on headers. Some had 14 bolt patterns. Mine had the exhaust port just a little higher, so I had to elongate the bolt holes to slide the header up to stop the exhaust leak. I would buy the 390. If nothing else, you can always put the parts in your 360.
KOT390
I wonder if there are any aftermarket companies out there making pistons for the 360 that raises the compression. Last I heard there are none.
teason72
15
05-01-2012 08:05 AM
marc128000
06-10-2010 04:18 PM
vscrl
02-11-2010 12:16 PM
76 ford f-100
19
10-22-2008 09:48 PM
67f100
09-29-2005 11:53 PM
