360 Build
Old Mar 6, 2008 | 03:31 PM
Scifi266's Avatar
Scifi266
360 Build
Been through the forums for about 2 or 3 hours. And I got some good advice for my 360. What cam, intake, and headers would you guys recommend? I might do a 390 for another project; but for now I have my mind set on my 360. Would an intake from a 390 work on my 360?
I know you guys can help. Thanks
Old Mar 6, 2008 | 08:08 PM
85e150's Avatar
85e150
A couple hours on here and you should know:
--360 is hobbled by low compression ratio and "sunken piston" situation, so if you're going to do a 390, do it now.
--Almost all, if not all, the FE stuff interchanges.
--cam specs are provided by the cam mfg, and several posts here have some info.
--if you have a 390 4bbl manifold, that's good enough if you are staying 360. Use a 600 cfm carb.
--headers, whatever you can afford, longer tubes better. H pipe, twice pipes 2 1/4" to mufflers, 2 1/2 past.
--breakerless ignition.
How many miles on this 360? Everything working? No oil burning/leaks, excessive blowby, burned valves? Nothing brings out the effects of high miles like more hp and rpm.
There are a couple of threads where guys fiddled with their 360s and were happy with them. Intake/headers as I recall.
Good luck with it
Old Mar 7, 2008 | 01:33 AM
Scifi266's Avatar
Scifi266
Just couldn't pass smog. it was in a 71 f250, i'm putting it in my 66 f250 so smog isn't an issue.
