Hood Alignment
If there are new parts involved, it may be different curvature. I replaced the DS front fender, and wound up building up the fender with all-metal to get good alignment. Make sure that hinges and springs are attached and tight because the hood will flex. HF sells a whole box of body shims for around $5.
You can see its tilting up towards the drivers side. Makes it so the hinge doesn't want to sit flat against the hood.
on
AXracer
26
07-29-2023 10:54 PM
Trentonpro1
02-11-2018 01:26 PM
stayxcalm
08-21-2015 10:11 AM
