Hood Alignment
Any suggestions for getting the hood lined up properly without a co-pilot? It looks close, but as the passenger side goes up towards the cab, it sticks up above the fender line a little.
If there are new parts involved, it may be different curvature. I replaced the DS front fender, and wound up building up the fender with all-metal to get good alignment. Make sure that hinges and springs are attached and tight because the hood will flex. HF sells a whole box of body shims for around $5.
Originally Posted by Phil Woolfson
(Post 16386090)
try a thick shim on the rear hood hinge bolt only....the one that the hood bolts to nearest to the cowl panel.
no shims necessary.
Jeff, just make small adjustments on the bolts that hold the hinge to the firewall |
Originally Posted by Diesel_Brad
(Post 16386433)
no shims necessary.
Jeff, just make small adjustments on the bolts that hold the hinge to the firewall https://cimg3.ibsrv.net/gimg/www.for...6668e5a553.jpg You can see its tilting up towards the drivers side. Makes it so the hinge doesn't want to sit flat against the hood. |
Hook that ground back up ... :)
-Enjoy fh : )_~ |
Originally Posted by Festus Hagen
(Post 16386467)
-Enjoy fh : )_~ |
I see so many grounds left unhooked, folks wondering why things don't work right, that's all!
Thank you. -Enjoy fh : )_~ |
(Post 16386600)
