Hood Alignment
Old 06-27-2016, 04:19 PM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
Hood Alignment
Any suggestions for getting the hood lined up properly without a co-pilot? It looks close, but as the passenger side goes up towards the cab, it sticks up above the fender line a little.
Old 06-27-2016, 04:58 PM
Phil Woolfson's Avatar
Phil Woolfson
Phil Woolfson is offline
If there are new parts involved, it may be different curvature. I replaced the DS front fender, and wound up building up the fender with all-metal to get good alignment. Make sure that hinges and springs are attached and tight because the hood will flex. HF sells a whole box of body shims for around $5.
Old 06-27-2016, 06:21 PM
GuitarJesus
Its a factory piece from the JY.
Old 06-27-2016, 06:34 PM
mic91F150's Avatar
mic91F150
mic91F150 is offline
try a thick shim on the rear hood hinge bolt only....the one that the hood bolts to nearest to the cowl panel.
Old 06-27-2016, 07:49 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
no shims necessary.
Jeff, just make small adjustments on the bolts that hold the hinge to the firewall
Old 06-27-2016, 07:56 PM
GuitarJesus
Originally Posted by Diesel_Brad
no shims necessary.
That's actually what I was thinking. It's slightly crooked. Looked at my 94 as a reference.
You can see its tilting up towards the drivers side. Makes it so the hinge doesn't want to sit flat against the hood.
Old 06-27-2016, 08:02 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Hook that ground back up ...
-Enjoy
fh : )_~
Old 06-27-2016, 08:15 PM
GuitarJesus
-Enjoy
fh : )_~
All in due time my friend
Old 06-27-2016, 08:36 PM
Festus Hagen
Methanoholic
I see so many grounds left unhooked, folks wondering why things don't work right, that's all!
Thank you.
-Enjoy
fh : )_~
Old 06-27-2016, 08:46 PM
GuitarJesus
Thank you.
-Enjoy
fh : )_~
There's one on the hinge for the hood, the hinge is bolted to the body. Sort of a moot point anyway
AXracer
26
07-29-2023 10:54 PM
Trentonpro1
02-11-2018 01:26 PM
Mercman54
12-04-2017 10:57 PM
stayxcalm
08-21-2015 10:11 AM
zpmps2
11-25-2007 09:48 PM
Quick Reply: Hood Alignment
