tbo removal
Old 01-28-2016, 06:58 PM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
tbo removal
I get the 10 mm bolt -rear driver side turbo stand off- any ideas
Old 01-28-2016, 10:39 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
You got the hardest one if your talking about the bolts. Three more to go!
Old 01-29-2016, 06:10 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
no------ I- cant get --- that off-- looks striped
Old 01-29-2016, 06:12 AM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
all the other bolts are off
Old 01-29-2016, 07:14 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
Here's a link to a youtube video on removing a turbo. I used a 1/4" drive socket and a 1/4" universal joint and got it out. You can wrap tape around the universal joint to keep it from flopping around too much.
If the bolt head is stripped, I don't know what to tell you. Maybe somehow get back there with a die grinder and grind the bolt head off, then take what's left of the bolt out with vice-grips once the pedestal is off. I doubt it's stripped though.
Old 01-29-2016, 07:54 AM
finallyo3gt's Avatar
finallyo3gt
finallyo3gt is offline
I haven't done this job before, but wobble's are your friend. They have range of motion like a swivel but don't flop as much and don't bind.
Old 01-29-2016, 11:48 AM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
I used a 1/4" drive 6pt 10mm swivel socket.
Robot Check Robot Check
Piece of cake with this.
If it really is stripped you'll have to do what was suggested above unfortunately.
Old 01-29-2016, 05:35 PM
1bigjoe's Avatar
1bigjoe
1bigjoe is offline
thank you all----got it off
Grannygear
04-01-2016 08:53 AM
Talyn
06-09-2010 09:23 AM
oldbird1965
02-17-2010 10:25 PM
Nick 99
28
10-05-2009 06:25 PM
dryfly
10-08-2007 11:47 AM
Quick Reply: tbo removal
