Just installed new Power Max turbo on my 2005 F350 SD 6.0. I got it all back together and discovered I had a spare bolt. I found it under the truck on the ground. When I removed the turbo I took out the 3 mounting bolts from the pedestal and kept them together. I did not remove any other bolts in removing the turbo. I did not drop a bolt. I have it all back together using the new bolts supplied in the reinstallation kit. Now I am afraid to start my truck up. the 3 bolts on the right in the photo are ones from the turbo mount. They all have PB Blaster or some other spray to loosen them up. The other has none. Any help or thoughts about the 4th bolt would be appreciated.
Randy
PS - I tried loading a photo of the bolts, but was unsuccessful. All four bolts are identical and 3 are turbo mounting bolts.
