Blend door help needed
Old 12-18-2013, 10:10 PM
TheProfessorofTOOL's Avatar
TheProfessorofTOOL
TheProfessorofTOOL is offline
Over the last weekend I pulled my dash apart and replaced my heater core and blend door. My problem is now it seems as though the blend door is stuck open, as in it only blows hot hot hot air. It sounds as if the blend door actuator is working because I hear it move but not very much. Besides pulling the dash apart again is there anything I can do to fix it? Has anyone heard of this happening??
97 f150 ext cab 4x4 4.6 e4od trans
179xxx miles
Old 12-18-2013, 11:10 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
You might try removing the actuator and try moving the door manually to make sure it's not binding.
Old 12-19-2013, 08:51 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
you can take the plastic off above the trans hump and below the radio and get access to the control motor without pulling the dash.
Old 12-19-2013, 09:15 PM
texastoolman's Avatar
texastoolman
texastoolman is offline
I agree, sometime on other vehicles there is a stop in them and the door might be stopping it from reaching it's limits
jdvern
2004 - 2008 F150
10-23-2008 06:04 AM
jdev6
12-11-2007 09:34 AM
tex599
06-07-2004 03:19 PM
tex599
1997 - 2003 F150
05-13-2004 10:39 AM
imsorope
1983 - 2012 Ranger & B-Series
10-11-2003 10:23 PM
Quick Reply: Blend door help needed
