Sponsored by: Auxito
Blend Door Problem
Old May 12, 2004 | 08:20 AM
tex599's Avatar
tex599
Blend Door Problem
99 F150, A/C blows hot air through vents. It is a blend door problem. I took the blend door motor out yesterday and it works fine. It feels like the door is broken. Can you replace just the door? Do you have to disassemble the whole dash to get to it. Any one have any advice on this?
thanks
Old May 12, 2004 | 01:01 PM
FourthFordTruck's Avatar
FourthFordTruck
Tex, do a search in this forum, there is a blend door fix that will save you lots
of dough. Good luck.
Old May 12, 2004 | 02:28 PM
tex599's Avatar
tex599
I know about the fix but do I have to remove the whole dash to get to it?
Old May 12, 2004 | 02:41 PM
FourthFordTruck
The thread I'm talking about would tell you.
I read it a couple of months back.
Old May 12, 2004 | 06:36 PM
Racerguy's Avatar
Racerguy
To replace the blend door you have to remove the whole dash. The blend door isn't available seperately from Ford. They only sell the complete heater plenum assembly.
Hopefully HomerWinzlow will be here soon with some ideas for you. He seems to work on lots of these.
Old May 13, 2004 | 09:42 AM
tex599's Avatar
tex599
Removing Dash
I have removed almost everything except for the large single piece. I can't seem to get it to disconnect around the passenger airbag. Anybody have any ideas?
thanks
Old May 13, 2004 | 10:39 AM
davidep's Avatar
davidep
Heater Blend Door Fix
I just did the heater blend door fix that I saw on this site yesterday and it worked great. You do not have to remove any of the dash to do the fix. You just have to lower the glove compartment and remove the blend door actuator and modify it a bit. This saves a lot of time and money and works great.
shakedownshorty
Nov 11, 2014 01:38 PM
ppruitt
May 29, 2014 06:32 AM
fnx4wheeler
Sep 19, 2013 01:10 PM
desertbronze
1997 - 2003 F150
Dec 27, 2010 02:26 PM
mbranagan
Oct 30, 2010 07:23 AM
