Vehicle Speed Sensor
I hate to ask this but my experience with this truck is very limited to say the least. But, I have a 99 F-350, 7.3L, 4WD and the speedometer quit working, ABS light is on, and the overdrive light is flashing. The Ford dealer told me they needed to replace the VSS to trouble shoot the problem. I have replace the sensor in the differential with no results. I purchased a vehicle speed sensor which supposedly is installed in the transmission but I can't find where this sensor is at. The picture is the one I purchased but again I cant find one like it on the transmission / transfer case. Help please.
Transmission Speed Sensor New Pickup E150 Van E250 E350 F150 Truck F250 F350 | eBay
on
Looks like the same one RockAuto has....
More Information for AIRTEX / WELLS 5S4713
As you said though, it doesn't look like it would go where it is supposed to on the transmission.
Does this match the one on the tailshaft of your transmission?
More Information for STANDARD MOTOR PRODUCTS SC210
The one that you showed is the older style back when they still
had a cable to run the speedometer. It would of gone onto the tail-shaft
housing of the transmission or transfer case on the 4X4.
Check the plugs and wiring up into the harness for any damage.
The other thing to look at would be your front wheel sensors and
see if you have a bad one. Also I would find a new dealership
they should be able to pinpoint that without having to replace the part.
Someone is being lazy IMHO. One other thing to check is if there was any other
work done to the truck. Look around where the work was done. If no work
was done did it come one all of a sudden? Did ANYTHING happen before?
Sean
Sean
Where you are going wrong is that there is no vehicle speed sensor on your transmission. You'll never find one no matter how long and hard you look. The two sensor you have shown above are the turbine speed sensor (TSS) and the output speed sensor (OSS.) Neither one reports vehicle speed.
The ONLY VSS (Vehicle Speed Sensor) is on the rear axle. A code for a VSS doesn't necessarily mean that the sensor is bad, it means the PCM doesn't see the signal. Quite often the problem is a damaged wire between the VSS and the PCM.
ronjon95
02-26-2011 08:26 AM
fordbabe0014
11-30-2005 06:21 PM
dheffley
07-27-2003 05:09 PM
