Over Drive Light Speed sensor????
Old Feb 25, 2011 | 10:31 PM
ronjon95's Avatar
ronjon95
I have a friend that has a Early 99 with auto trany. His OD light flashes or stays on. Then the Speed dial stops working or jumps around. last time this happened I pulled a fuse not real sure at this time which one and a moduel reset and it was fine. This was several months ago. then again since where getting rain he says its happening again. I have found if I am correct 3 yes Three different speed sensors. 2 on the trany one on the hog of the rear end. Help what do I look for?
Thanks Guys!
Old Feb 25, 2011 | 10:58 PM
mueckster's Avatar
mueckster
The usual culprit is the VSS/ABS sensor in the top of rear differential housing. Have you pulled the codes yet?
I bought the sensor for wife's exploder for less than $20 at a parts store.
Old Feb 25, 2011 | 10:59 PM
clintbonnie's Avatar
clintbonnie
First remove the sensor on top of the rearend and just clean it .. reinstall and try it.. If that doesn't fix it... replace the sensor.. go to napa and ask for p/n 530780.. about $12.
Mine did the same thing a couple of years ago... on my E99.
Old Feb 26, 2011 | 08:26 AM
Ponyboychris's Avatar
Ponyboychris
What they said, easy fix. You don't even need to jack up the truck to reach the sensor.
JoshuaHancock804
107
Aug 5, 2016 08:32 PM
CS qualls
New Member Introductions
Dec 2, 2014 10:58 AM
kralldaddie
Nov 1, 2009 12:14 PM
Glockem45
Sep 1, 2009 09:08 AM
keepkoolac
May 23, 2004 09:33 AM
