Vehicle Speed Sensor
Old Nov 1, 2007 | 09:36 PM
bobfromktown's Avatar
bobfromktown
For the past couple of hours I have been looking for my vehcile speed sensor and I can't find it anywhere, it is not on the rear diff, that is the abs sensor, and I can't find it on the transmission or t-case, I have a 351-w, e4od, borg warner 1356 electric shift tcase.
Old Nov 1, 2007 | 09:43 PM
Skandocious's Avatar
Skandocious
On your year truck the RABS sensor is used also as a VSS.
Old Nov 1, 2007 | 10:26 PM
bobfromktown
Well, the thing is the year truck that I have also has a VSS according to Auto Zone Napa and Orielley. So I don't know what to do
Old Nov 1, 2007 | 10:44 PM
Skandocious
Looked in my service manual and it listed this for vehicle speed sensor:
The speed sensor, mounted on the rear of the transfer case (7A195), tells the electronic control module the speed of the vehicle to allow range shifts (in or out of 4L) to occur.
I believe it looks like this:
That is basically the sensor that allows you to shift an electronic 4x4 into low range depending on your speed. The sensor will not allow it if you are going too fast. I'm assuming that you're looking to replace the RABS sensor.
Old Nov 1, 2007 | 11:02 PM
bobfromktown
well, where does that sensor go, there is not one on my transfer case, I purchased the rear abs sensor.
Old Nov 1, 2007 | 11:26 PM
Skandocious
To be honest bob I'm really not sure... Lol
Looked at my transfer case and I definitely don't have that sensor... Either way, you're probably looking to replace the RABS sensor. You should be fine.
Old Nov 2, 2007 | 04:39 AM
EPNCSU2006's Avatar
EPNCSU2006
The parts stores have not figured this one out for some reason. The only VSS on 92 and up trucks is the sensor on the rear end, but for some reason the parts look-ups still list the older VSS that goes in-line with the speedometer cable. Since the 92-up trucks don't have a speedometer cable, there's no place to put the older VSS. Basically what I'm trying to say is, don't go crazy looking for that VSS pictured above, because you won't find one on a 96.
Old Nov 2, 2007 | 08:57 AM
bobfromktown
yeah I went crazy looking for one last night, I should have got on here first before going to the auto stores, the people there had me convinced that mine fell off or was ripped off or just not there. Thanks FTE I owe you once again. I already purchased the rear abs sensor and we should be good on that, I will be putting that in today, thanks guys.
Old Nov 2, 2007 | 09:21 AM
Skandocious
Man!! And here I was tearing my hair out trying to figure out why rockauto listed that as a part for these trucks... Haha, wish you woulda shown up sooner Eric. I knew there was something wrong with this whole situation...
Old Nov 2, 2007 | 10:23 AM
quicklook2's Avatar
quicklook2
fte should send an email to all the major parts stores and inform them of this.
Old Nov 2, 2007 | 10:39 AM
subford's Avatar
subford
A lot of the Ford dealers have this wrong also along with the wrong Ignition Module for the 1994 - 1997 trucks.
Old Nov 2, 2007 | 11:14 AM
quicklook2's Avatar
quicklook2
we will have to add them to the list then.
Old Nov 2, 2007 | 11:50 AM
bobfromktown
Hey do any of you guys know the part number or where I could possibly get the shift on the fly switch that is in the dash, says 4x4-low range, and has a little light next to it. Thanks for any help I can get.
Old Nov 2, 2007 | 02:06 PM
quicklook2's Avatar
quicklook2
go to left column and find national parts depot and download a pdf manual.
Old Nov 2, 2007 | 04:12 PM
Skandocious
I already checked there for him. Doesn't look like they sell it. Neither does LMCTruck or Direct Ford Parts.
