Injector Suggestions?
I am due for new Injector o-rings, as some may have seen in my previous thread.
Currently I am looking for more power. I use my Early 1999 F250 6-speed as a daily driver. Everyday I have to merge onto a 55mph highway during morning rush hour. In a car, this task is easy. In a 6 speed 7.3 Powerstroke, it's a little bit more difficult. I sometimes find myself waiting for a large enough gap or small enough car for up to 15 minutes.
Since I need new injector o-rings, is this a good enough excuse to buy larger injectors? I have over 315,000 miles on the truck.
If so, what size injectors do you guys suggest?
I will be installing a 6 position chip from PHP.
Thanks so much!
Thanks so much!
I believe my injectors have leaky O-rings, I can hear them clacking, they have 1/4-million miles, and I have been on a tear to get more MPG since day one (with great success so far). I'd like to know this one as well (subscribing). I will be researching the differences between stage 1s and hybrids (on my list so far). I've heard the rumors of improved performance/MPG on injector upgrades, but I haven't read any numbers from the people who drive the rigs with these installed. Does anybody out there with upgraded injectors and improved fuel economy have a story to tell?
Stage 1 injectors generally use stock nozzles but more fuel (165cc vs. 130cc on your stock injectors.). Stage 2 injectors generally bring the cc's up and also increase the nozzle size. Stage 3's are what is usually considered a hybrid injector. They flow more fuel (238-400cc's) with less oil as the plunger is out of a different injector (hence the hybrid name).
You may find by simply adding a chip you will have a whole different animal. Also I suggest making sure the truck is properly maintained and up to specifications. You may have an up-pipe leak that will cause it to feel sluggish. That has a big impact on the turbo spooling up.
The sequence I would take, if I had it to do over again (I went a little out of sequence):
- Make absolutely certain there are zero exhaust leaks between the block and the turbo.
- Find the means to make sure all your Exhaust Back Pressure and MAP sensors are working correctly.
- More air in - 6637, similar, or AIS (I prefer AIS)
- More air out - 4" exhaust from the turbo out.
- Gauges - EGT, Transmission Temperature, and Boost at a minimum.
- Chip. Everything else will give you a boost in power, but this is the real deal.
The sequence I would take, if I had it to do over again I went a litlle out of sequence):
I have done the 6637 mod already, along with a short 4" turbo back exhaust that runs in front of the rear wheels.
I just ordered gauges today, also about to order the Over-Boost regulator from RiffRaff.
I also just put in a 450hp South Bend Clutch, Pressure Plate, and Flywheel.
I'm almost positive that there are no exhaust leaks, everything seems solid. How can I further check for leaks?
As for the leaks: If you have no soot in the engine compartment, the Boost gauge will let you know if anything else is up.
Have you ever ridden in a tuned 7.3? You would be amazed at how it will wake your truck up. Have you checked the life of your HPOP? Switching to a late 99-03 set up would help you out too. TO check for boost leaks on the exhaust side get out a flash light crawl under the truck and see if you can spot any soot on the collector its hard to see, check the manifolds up-pipes etc. With stock tuning you should be around 15-17 psi boost
