Was wondering if anyone had the part number for shifting linkage that goes from the column to the tranny.
1968 F100, as original: 240 or 300 I-6: C4 Cruise-O-Matic, trans pan has 11 bolt holes / 360 or 390 = C6 Cruise-O-Matic, trans pan has 17 bolt holes.
AOD introduced in 1980 Passenger Cars, was not available until 1981 in F100's. So, with a 1983 302, it could be an AOD, but it could also be a C4, as both A/T's were available.
Swapped engine/AOD transmission: You will not be able to use 1968 parts. If the swapped in 302 has a C4 behind it, then the original parts might work, might not...depends if the C4 is original to the truck.
so i best bet will be to get some steel rod and start making one that will work? i have one,but the the distance between park and first is about an inch one the column, thats with it adjusted all the way out.
thanks
