1968 F-100 Steering column
Was wondering if anyone had the part number for shifting linkage that goes from the column to the tranny.
Thanks |
For which transmission?
It has a cruise meteric, is that a AOD? It also has an 1983 302. Or maybe a diagram with measurement, so I can make on.
Thnaks |
Metric, was what I meant
did you mean cruisematic ? that was the old c4 transmission
Nope, that's what I thought, but the pan says cruise-o-metric. I think it might be a AOD, so I'm really confused
Here are a coupla pics to ID your tranny:
https://i8.photobucket.com/albums/a3...C4AODpanID.jpg Or: https://i8.photobucket.com/albums/a3...transpanid.jpg |
Originally Posted by deerbuster
(Post 11251039)
AOD introduced in 1980 Passenger Cars, was not available until 1981 in F100's. So, with a 1983 302, it could be an AOD, but it could also be a C4, as both A/T's were available. Swapped engine/AOD transmission: You will not be able to use 1968 parts. If the swapped in 302 has a C4 behind it, then the original parts might work, might not...depends if the C4 is original to the truck. |
so i best bet will be to get some steel rod and start making one that will work? i have one,but the the distance between park and first is about an inch one the column, thats with it adjusted all the way out.
thanks |
from the pictures above its a AOD
Number Dummy, is there a way that i can contact you? i have a few oddball questions about this rebuild of my truck.
