Emergency brake setup for 8.8 Rear
I have a 2000 Explorer 8.8 all setup in my No Limit 4 bar and I am trying to figure out how the emergency brakes will work. Its a Disk brake setup and I have the cables from the caliper on each side but that is it. Can I somehow make this work with the stock setup, or would it just be easier to go get the rest of the setup from the Explorer and fab that pedal in?
Thanks
Kelly
Thanks
Kelly
Keep it stock
Kelly;
I used 2001 3:73 from Explorer on my '50; used stock handle and cable from cab; then transitioned to rear bracket from Explorer.
Took very little effort; and does work. I originally tried using compression fitting, which "slipped off" so used a loop connection and fabbed short straight section with bolt through it. So far , so good.
Thanks
Kelly
Thanks
Kelly
I bought custom cables from a foot pedal to the rear connections.
A cable from pedal to junction under the cab, and two cables from the junction. See http://store.controlcables.com/servl..._streetrod.htm
Sam
On my F1 with stock e brake handle, I bought a Lokar brake cable and ran it along the left side frame rail. I connected the two cables from the rear into a fabbed T bar which attaches to the lokar cable. I used stock explorer cables running across the axle in a stock fashion. I read an article in Street Rodder a few year back that used all lokar parts and ran the cable down the center from the handle/pedal to lokar cables from the axle forward. That worked fine, but it's alot more money.
Hey Kelly,
Let me know what direction you go on this one - I've got an Explorer 8.8 going in mine as well - Saving it to the end as the chassis has wheels & rolls now. I was looking at a foot pedal in the lower driver's side.
Ben in Austin
(I'm tired of this crappy heat - 112 degrees in Austin today - tied for the hottest day ever since they have been keeping track in the 1850's. I'm about fully cooked over here - I have no idea how Sam is out working on his truck in this).
Ben in Austin
Hey Ben,
I will keep in you in the loop. I will take a look at the old setup this weekend so I can start to figure out how to hook the two together.
I hear you about the heat, my Dad and I have been working all summer and we have have lost some weight out there in the garage. I can't wait till October gets here.
Sam I will take a look this weekend to see how the brake setup works. I have not even pulled the rotors off yet. Its still the way it was when I grabbed it at the Junk yard.
Hey Kelly,
Ben in Austin
Ben in Austin
go out to the shop, turn on the big wall fan, open the 10x10 door
when u start to drip on the parts, quit..
Sam
I am hopping on this thread also, stealing the best idea hope ya'll don't mind!
I cleaned and painted my 8.8 explorer axle this weekend. had a wheel stud to replace so I pulled the cover, axles from the housing. I went to harbor freight and bought a slick rear axle bearing remover! pulled the seals easily then used the remover on the end of a slide hammer and those bearings were putty in my hands!
I bought oem e-brake cables for mine a couple days ago. And it is a disc brake unit. so i am interested in learning!
After choosing the explorer disc rear I also had the same questions, solved by looking under several different models of cars/trucks and gathered up about a bucket worth of odd-shaped metal chunks of stuff. Oddly enough most of it was from other explorer's brake cables. One coupler was from a Jeep Cherokee..I ended up cobble'ing just enough together to make it work. Before I got too far, I completely dissasembled the brakes and cleaned /lubed everything ..the stock cables needed the most attention to operate smoothly, remember to leave 'some' type of adjustment somewhere...
My 49 F-1 emergency cable ends in a threaded fitting. In the corvette they use a "parking brake cable equalizer" from 1964 -1982. With this you can use a single cable from one rear brake to the other or two cables run through the equalizer and use cable clamps. The part works using the stock cab handle and cable back to where it splits. Use stock threaded fitting and fit through the equalizer and add a nut on the threaded fitting. Google,there is a picture of the part. You could make this part. chuck
Ford_250
12-27-2007 03:51 PM
mark914
09-16-2006 02:25 PM
