Parking Brake Help
Old Jan 19, 2018 | 05:35 PM
jakevidrine's Avatar
jakevidrine
Parking Brake Help
I replaced my rear end with a Ford 8.8 out of a 1999 explorer, I now have disc all around with the drum parking brake in the rear. I would like to use the factory park brake lever on the dash but I am having a hard time finding a parking brake setup that will work...
I've looked on rock auto for the replacement explorer brake cables and they aren't very expensive but I'm not sure it will work, I don't have the plate to join the two cables together...
I understand there is a lokar setup but all the ones I've looked at don't have the cable to run back to the parking brake lever.
What is everyone using for this swap?!
Old Jan 19, 2018 | 06:12 PM
mod22's Avatar
mod22
this is the cable I used to go to original ebrake handle Lokar EC-8000HT you will also need the rear lokar cables
Old Jan 19, 2018 | 08:32 PM
Gicknordon's Avatar
Gicknordon
I used the lokar cables and made a little bracket to hook my original park brake lever up to it. Mine is a 48 but I would think the same thing would apply. Its just a piece of square tubing with a hole drilled in 1 end to hook to the lokar clevis and a slot in the other for a cable clamp to fit into to clamp the stock brake lever cable.
Old Jan 20, 2018 | 10:17 AM
tip49's Avatar
tip49
Parking brake linkage
https://www.ford-trucks.com/forums/1...my-1949-a.html
blue924.9
Sep 2, 2015 07:27 PM
Kazoo
Dec 2, 2012 11:21 AM
PJBIII
Jun 23, 2011 11:43 AM
bad_habit59
Feb 12, 2009 12:20 PM
MikeGV
Feb 6, 2005 09:43 PM
