1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Steering Wheel Wobble
Old 12-24-2010, 12:48 AM
atomrat's Avatar
atomrat
atomrat is offline
My truck has developed a wobble in the steering wheel. I don't mean when you are driving down the road, but the steering wheel wobbles around. It wobbles in any position that the Till shaft is set to.
Please advise on how to repair.
Thanks in advance.
Old 12-24-2010, 01:38 AM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
Not sure I understand the question...
Wobbles around like it's loose? Or appears out of round when turning it?
Old 12-24-2010, 02:05 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
I think he is saying there is a lot of slop in his tilt mechanism causing it to shift around.
Old 12-24-2010, 02:44 PM
atomrat's Avatar
atomrat
atomrat is offline
There is a lot of slop in the steering shaft from the tilt to the steering wheel. The tilt still seems very tight.
When I grab the steering wheel, it will move side to side about 1/2" to 3/4".
Old 12-24-2010, 02:56 PM
bunklash's Avatar
bunklash
bunklash is offline
Do you mean the whole wheel moves side-to-side, or that it rotates 1/2" to 3/4"?
Old 12-28-2010, 12:14 PM
atomrat's Avatar
atomrat
atomrat is offline
The whole wheel moves side-to-side.
Old 11-10-2011, 06:15 PM
marc13's Avatar
marc13
marc13 is offline
Steering wheel is loose near tilt.
My truck started making cracking noises this morning and now the steering is loose a few inches away from the wheel itself. I started removing stuff, the airbag and lower shroud behind the wheel is off.i have no idea how to remove the upper shroud with the ignition going through it or what I need to replace on my steering. I've been researching road problem for a few hours now and have had no luck. I know I need a big torx bit for the wheel to ber removed but after that I'm lost.
Old 07-13-2014, 04:30 PM
Lakvoodoo's Avatar
Lakvoodoo
Lakvoodoo is offline
Trailering
Did you ever get an answer on this question?
(I'm having the same issue....some play in the steering wheel, making it a bit unnerving when driving on the highways. )
Thanks in advance.
Old 07-13-2014, 05:11 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
All new users with the same predicament ?!?
Hope I'm wrong with my opinion ....
Old 07-13-2014, 05:19 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Me thinks from 2010...he probably sold it ...very old post
Old 07-13-2014, 06:56 PM
Lakvoodoo's Avatar
Lakvoodoo
Trailering
Looking for some guidance (so I can be a little better prepared at our only shop in the area) vs opinions. Mine's a 2005 Excursion.
Badfish1060
05-05-2017 05:48 AM
Firefighter 1406
1997-2006 Expedition & Navigator
12-28-2016 08:34 AM
Greynomad
09-04-2016 07:17 AM
chris starscream
1961 - 1963 F100 Unibody
10-21-2015 03:56 PM
schonauer
05-08-2014 02:40 PM
Quick Reply: Steering Wheel Wobble
