Sponsored by: Real Truck
Fix wobble
Old May 3, 2017 | 12:41 PM
Badfish1060's Avatar
Badfish1060
Fix wobble
Got the death wobble, had everything replaced.
Wobble was worse, upgraded track bar.
Then no wobble but bad bump steer.
Put on new OEM track bar.
Ok but still if I hit a hole on the interstate I get death wobble and little mini wobbles on any bump.
What is the permanent fix for this other than selling the truck?
TIA.
2011 6.7L FWD Lariat, upgraded exhaust and Def removed.
Old May 4, 2017 | 10:11 AM
Ford744's Avatar
Ford744
Do you have a steering stabilizer? I remember years ago there was a lot of problems with death wobble. Hows your alignment?
Old May 4, 2017 | 01:32 PM
fishbones182's Avatar
fishbones182
Steering stabilizer, tie rods, ball joints, tires many things can cause the death wobble. Unfortunately there's not just one easy fix for the issue.
Old May 4, 2017 | 02:28 PM
Badfish1060
Is this the add-on stabilizer? I was thinking about getting that done. I have replaced everything else.
Old May 5, 2017 | 05:48 AM
CollinsCD's Avatar
CollinsCD
Wow, you threw a lot of parts at it and still having the issue. In my case, new steering stabilizer, shocks and tires cured my wobble issue.
Philisophe
Oct 30, 2018 10:59 PM
n3wpv
Apr 20, 2016 03:53 PM
03X
Nov 26, 2015 09:14 AM
MRMlandscapingDE
6.4L Power Stroke Diesel
Oct 23, 2015 09:15 AM
lonlyknight
Jul 1, 2013 10:48 PM
