Grabbed a 351 from a pick 'n pull last week...
Old Yesterday | 12:01 PM
Duke5A's Avatar
Duke5A
...and in all my time wrenching on brand X rot boxes up here in the rust belt never have I had the issues I've had with Ford. Is this normal? I snapped two bell housing bolts, multiple intake bolts, rounded three motor mount bolts and needed a four foot pry bar with heat to remove the distributor. Absolutely nuts. Everywhere a steel bolt came in contact with aluminum it was oxidized in place. It was only through the generosity of a complete stranger at the yard (Thanks Ralph!) who happened to have pry bars and hammers were we able to separate the E4OD from the engine block. After I got it home the cherry on top was the distributor being one with the block.
So yeah, I'm building a roller 351. lol.
Old Yesterday | 01:24 PM
90project5.0's Avatar
90project5.0
Maybe it was submerged for a few years?!
Old Today | 08:49 AM
cougrrcj's Avatar
cougrrcj
That's typical engine rust for 4x4 plow trucks here in the Rustbelt! - and even some of the more regularly winter driven trucks. You guys in non-snow areas don't know how bad we have it here...
It looks like at least one of the water pump bolts snapped off - those on the top center are a PITA since they thread into the aluminum timing cover and have through-holes... same goes for the end intake manifold bolts - I see at least the two on the front broke off in the heads...
Old Today | 08:58 AM
Sedonut's Avatar
Sedonut
5th Gear
Sometimes things in the scrap yard should just stay in the scrap yard. I just bought a1984 Arizona F250 and not a single stuck bolt. Broken valve spring, and almost no brakes, but virtually no rust.
Old Today | 09:19 AM
Duke5A's Avatar
Duke5A
Inside of the motor looked fairly clean with no significant sludge build ups. First thing we did was pop the valve covers, plugs and roll it over before attempting to pull it out. I got it to the machine shop last night and on the shelf they had a set of alloy heads they rebuilt for a good price, so I told the guy I'd buy them too. All that is getting used out of this is the short block now. That timing cover might get replaced. Need to find an intake still as well. Fun stuff.
Old Today | 09:46 AM
Hit Man X's Avatar
Hit Man X
Nice snag, what did it set you back?
Plans for the rest of it?
Old Today | 10:24 AM
1Butcher's Avatar
1Butcher
My junk yard engine was pulled by the yard. For $50 more, it was well worth it. Because there was water in it, it was sold as a core. The engine did turn which was important to me. I got the 'core' for $200. I was expecting to pay $1000 for a roller engine, I think I made out fine. All of the parts are ready to make it a 408 as well as the machine work.
Old Today | 10:26 AM
Hit Man X's Avatar
Hit Man X
Mine was $250 pulled, worked for me. Probably should use it some day
Old Today | 06:00 PM
Duke5A's Avatar
Duke5A
I paid $300 for it and that was only because I wasn't able to strip it down far enough. Even if it wouldn't have fought me there wasn't enough time - that yard runs on banker's hours. Honestly, I probably should have looked a bit longer, but these motors are getting hard to come by around here anymore.
Plan is for a mild build with a slightly hotter than stock cam that runs on 87. The machine shop has a set of Pro Comp alloy heads they rebuilt for $800, so those are going on with an Edelbrock Performer, Holley Sniper and SS shorty headers. Nothing crazy.
egchewy
23
Mar 29, 2023 09:18 PM
Texasknowhow
Sep 5, 2020 09:06 AM
JPIECHOC50
Aug 31, 2020 11:19 AM
RussianWolf
Aug 13, 2006 05:37 PM
sparked135
Jul 22, 2003 11:46 PM
