Which 351 is this??
Old Aug 12, 2006 | 12:12 PM
RussianWolf's Avatar
RussianWolf
Which 351 is this??
Ok I have no clue.
I have been sworn to that its a Windsor.
I have been preached about how it was a Cleveland.
I have been harped upon about it being the M.
I have a pic I took of it from the front.
I paid 350$ for the truck.
I dont think I was ripped off.
I know the engine come out of a 76 Torino 'I think'.
Identify plz.
Old Aug 12, 2006 | 11:06 PM
chrono4's Avatar
chrono4
where is the thermostat housing bolted to, block or manifold?
Old Aug 13, 2006 | 12:57 AM
grclark351's Avatar
grclark351
to the right of the distributor as you're facing the engine, is there a 1" tall rib of metal sticking up from the block? are the 2 bolts that hold the fuel pump on up and down or across? the intake does not look wide enough for it to be an M/400. can you get a better pic of where the thermostat housing attaches, the radiator hose is in the way in that pic.
Old Aug 13, 2006 | 04:45 AM
dkstuck's Avatar
dkstuck
Looks like 6 valve cover bolts to me, windsor. Could go with better pic's and info.
Old Aug 13, 2006 | 07:26 AM
2020's Avatar
2020
Windsor,it has the 6 bolt valve covers.
Old Aug 13, 2006 | 05:37 PM
Matts72's Avatar
Matts72
Yep... valve covers gave it right away, Windsor. Thermostat housing is also mounted to the intake and timing chain housing isn't part of the block on a Windsor.
Welcome to FTE...
