Mount point for SAE connector
Old Yesterday | 05:11 AM
Grinkle's Avatar
Grinkle
5th Gear
2022 F350 Lariat
I want to mount a 12V SAE socket somewhere external to connect a battery maintainer to. The socket is small, if you haven't seen one its the kind you can plug a solar panel into. I can put it under the wheel well but then its going to get hit with anything that flies off the tire.
I'd like to put it somewhere on the bumper or behind the license plate holder without putting a hole in the bumper. Does anyone have any suggestions for a good mount point or know of a no-drill bracket I could buy to attach to the bumper and then attach the socket to?
Old Yesterday | 07:07 AM
speakerfritz's Avatar
speakerfritz
You can use clamps like this to mount the wire anywhere.
depending on the wire thickness…a1/4” clamp would probally be a snug fit.
simple install…determine a path from your battery to where ever you want the connector to land…..look for screws or bolts along that path and install the clamps with the wire in it.
should be simple.
i have an sae connector and wire installed in my truck mainly for an occasional dash solar panel….i can tell you that manufactures of sae gagets are not always on the same page and sometimes red is not red and black is not black. Some volt meter testing might be needed .
Old Yesterday | 08:10 AM
Grinkle's Avatar
Grinkle
5th Gear
I don't see an image - I'm new to these boards so maybe I'm missing something.
Old Yesterday | 08:32 AM
torq'ta 5 8's Avatar
torq'ta 5 8
me either
Old Yesterday | 09:06 AM
speakerfritz
Old Today | 02:18 PM
Gladstone's Avatar
Gladstone
I installed this flanged SAE connector
just above the passenger tow hook and hardwired it to the battery
Old Today | 06:00 PM
Grinkle's Avatar
Grinkle
5th Gear
Originally Posted by Gladstone
I installed this flanged SAE connector just above the passenger tow hook and hardwired it to the battery
I like that spot. What did you do for the mounting connectors? Machine screws? Any lock-tite or similar?
Old Today | 06:03 PM
Racer4's Avatar
Racer4
I need to get some of those for my tractors. Thanks for posting your solution.
Old Today | 06:06 PM
Gladstone's Avatar
Gladstone
Yes, stainless machine screws and nylocks. The plastic panel comes out making it a lot easier to install.
woodcarver62
Jul 23, 2022 02:13 PM
Supercab
Nov 29, 2019 06:45 PM
Shortys27
Paint & Bodywork
Apr 30, 2010 09:48 PM
02GrayPowerStroke
Oct 30, 2009 11:51 PM
