What do I need to install a winch?
Old Oct 30, 2009 | 03:16 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Will I need a new bumper too? I am clueless about this. What will I need besides a winch?
Thanks for your input.
Old Oct 30, 2009 | 03:28 PM
Robert6401's Avatar
Robert6401
There are different options here. You can mount a replacement bumper with the mounting point for the winch, you can put on a brush guard with a winch mount such as the Warn Trans4mer. Or you can do the mult-mount which uses a 2' receiver mounted behind the bumper. Check out Warn Industries website and you will see a lot of different options.
Old Oct 30, 2009 | 03:32 PM
schlepprock250's Avatar
schlepprock250
I like the idea of having a custom reciever mounted to the front,run the proper wiring harness,get a winch mounted to a plate that goes into the reciever,that way you can pull yourself out from the front or the rear(or pull some else out from the front or rear).
Old Oct 30, 2009 | 10:29 PM
bigdummyford's Avatar
bigdummyford
winch mount
I have this idea to use a piece of 6 inch chanel, square tube, heavy angle, and some plate and make an approximately 6 inch deep spacer to put a winch behind that will allow me to still mout the stock bumper. I figure with that I can also do a front mount reciever for putting a cable hook or another block for doubling or quadrupling my pulling power as well as for moving trailers. I could use the original tow hook mounts and bumper flanges to mount the spacer with a fabricated flange out front for attaching the bumper, i can buld shallow boxes over the winch to store the blocks and straps and some chain out of the way even though itll be a bit o weight out front. Then it gives me also a reaaallly nice place to stand when I am doing mods or maintainence underhood.
Old Oct 30, 2009 | 11:51 PM
bigsteve1969's Avatar
bigsteve1969
about 2k bucks i would'nt fab up anything if it was me.i would put the hitch in front that way u could run a winch up front or back. they make a quick connect power option you can add to the setup. i wouldnt skimp when doing something like this alot of times its just taken as a light issue.
