Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
Drivers side clunking noise
Old 09-21-2017, 02:19 AM
mcamacho0613's Avatar
mcamacho0613
mcamacho0613 is offline
Hi there everyone, hopefully I am doing this right but first off i have 97 explorer xlt and let me tell you these are wonderful trucks when maintained well. I had ran into an issue one day where I was reversing out of the parking lot cranking the wheel right and that's when I herd the clunking noise. Didn't think to much of it till I drove up my driveway, turning the wheel right again, it clunks again. So I stopped where I was at, got out of the car to analyze the problem and first thing I noticed was the front passenger wheel was turned way more than the driver side. I pulled it into the garage so I could look underneath after it being jacked and first thing I notice on the inner driverside wheel was a nice clean strip of metal carved around the lug holes. Then I looked at the brake calipers and found that the calipers would be scraping against the inner wheel. Well I checked all the bolts and tightened everything that needed to be tightened and still have the clunking noise. I checked all the tie rods, control arms, and so on. I have read on a few forums that it could be a bad tie rod? If so I would like your guys input on the situation and what might be the issue here. Thanks for the help and hope to hear back from all.
Old 09-21-2017, 01:02 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
I notice on the inner driverside wheel was a nice clean strip of metal carved around the lug holes. Then I looked at the brake calipers and found that the calipers would be scraping against the inner wheel. ---
worn tie rods or ball joints cant do that. If the caliper is hitting the rim or scraping the control arm, then the wheel bearing is worn out, or the lug nuts are way loose... All these parts move TOGETHER when the lug bolts are tight... they cant hit each other unless the bearing is shot.
Old 09-22-2017, 02:54 AM
mcamacho0613
Makes sense. So how are you able to tell if a bearing is out
Old 09-22-2017, 07:57 AM
steve(ill)'s Avatar
steve(ill)
put a floor jack under the center of the A frame ( under the shock) and jack the tire up 2 inches off the ground..... grab the tire top and bottom with your hands and rock it in and out.... any free movement is not right.
Old 09-23-2017, 06:42 PM
Mikeman's Avatar
Mikeman
Mikeman is offline
From my limited experience with one Explorer and one Mountaineer, the wheel bearings fail around 150K to 180k miles. The one that failed at 150k didn't make any noise but had enough slop to wipe out the ABS wheel speed sensor. The other made a terrible noise but didn't have enough slop to wipe out the ABS sensor.
While you're looking for movement, check those lower ball joints. You just have to look where the motion is occurring when you do the wiggle test mentioned above. I had to do both sides on my V6 Explorer at 157k miles, but the V8 Mountaineer is doing fine with 192k miles. You'd think that the heavier engine would have worn that stuff out sooner.
Old 09-24-2017, 03:29 PM
mcamacho0613
Input on good or bad idea.
Thanks for the input. Ill go and check it out and see what happens. My Explorer has 260000 plus miles on it and is running pretty strong still. I know I'm bound to run into some problems with that many miles on it, so I bought a parts car which is a 1999 explorer with 160000 miles on it. On my 97 I replaced/cleaned the whole top half of the engine starting from the fuel rail to the ICIV. All new plugs and wires, got new sensors, thermostat housing, replaced all hoses, and topped it off with an engine flush. As far as suspension, new shocks, rotors, sway bar bushing and sway bar links for the front. The rear is just new shocks, rotors, and pads. My over plan is to swap out engines once the 97 goes out. I would like some input on that cause I don't plan on getting rid of the truck but later down the road I would like to put a 5.0 in there. Thanks
BAJI26
05-08-2011 12:25 PM
SNOW87
02-27-2010 09:35 AM
txcntryboi23
17
01-05-2010 05:40 PM
thefnswits
1999 to 2016 Super Duty
02-07-2006 10:20 PM
Bruker
Aerostar
12-09-2003 08:02 PM
Quick Reply: Drivers side clunking noise
