Im having the same issue dude.... and apperantly the other day the wheel was making a loud noise every time my wife turned right. so i dont no either????
Does either front wheel have any play once off the ground? With 2wd - did you check inner and outer bearings? I'd jack up the front - check for side to side and top to bottom movement in the wheel. Side to side movement can also be steering so have someone with you so all joints can be looked at while the wheel is being moved.
