1990 f150 2wd 5.0 w/ aod
While driving the truck I can feel in the floor board a steady vibration/roar right underneath my left foot toward the front LH wheel. The noise seems to get worse as i'm turning to the left rather than the right. Im also hearing a rattle the goes away when the brakes are applied comming from the RH side (it seems). Are these to related and what might this be?
Check that the lug nuts are tight, then move the wheel up and down ans back and forth and see if there is any play in the rod ends or ball joints, then pull the whells, check the brakes and then check the wheel bearings.
