Time Sert 5553 Question (Spark Plug)
Old Nov 14, 2009 | 08:56 PM
mudder1_2000's Avatar
mudder1_2000
hey everyone just wanted to through out a question regarding the time sert kit. Just had mine delivered and am looking for any useful tips or tricks to doing the job. Oh ya I am now a proud member of the flying spark plug club. Yay me. By the way it was the second one back on the passenger side. Any tips/advice would be great.
Old Nov 15, 2009 | 08:31 AM
turbolaser's Avatar
turbolaser
I just did that same plug about 4 months ago on my Expy. Took me about 2 hours. I had to unbolt the fuel rail so i could move it out of the way a little. I used a rubber glove in the plug hole to get tdc on the compression stroke then continued to crank to let the piston go down about 2 inches so i did'nt hit the piston with any of the tools. Rotate the crank with a breaker bar not with the key. Used an air ratchet to ream the hole and countersink, then threaded by hand. Use grease on the reamer, countersink and tap to minimize metal shaveings that fall into cylinder. Also attached a garden hose to my shop vac to suck chips from the cylinder and an air nozzle to try and blow chips out. You want to get all the chips out of the cylinder. Just follow the instruction in the time sert kit they are great and take your time. Good luck with your repair.
Old Nov 16, 2009 | 05:24 PM
mudder1_2000
Just to update. I re-threaded my spark plug hole yesterday with the time sert kit. I must say it is an awesome tool. The only scary part encountered was doubting myself whether or not the valves were closed. I knew they were but still it plays head games with you.
Old Nov 16, 2009 | 08:45 PM
madsonp's Avatar
madsonp
I blew the back plug out of the passenger side head, took it to a shop and had them do the treaded insert, then that blew out, had to get a new head. I hope you have better luck with it than I did.
Old Nov 16, 2009 | 11:43 PM
mudder1_2000
What type of insert did they use. I have heard rumors of shops using Helicoils and in return blowing out again. I have heard nothing but good feedback with the Time-Sert kit.
Old Nov 17, 2009 | 08:46 AM
cbradford's Avatar
cbradford
Just a hint, you can use compressed air to verify that the valves are closed, just pump compressed air into the spark plug hole and if air blow out the exhaust the exhaust valve is open and if blow out the throttle body the intake valve is open.
Old Nov 17, 2009 | 09:15 AM
mudder1_2000
That is the method I used. It was still a bit unnerving even though I knew they were closed.
Old Nov 17, 2009 | 10:44 PM
madsonp's Avatar
madsonp
They said it was the Time-Sert but I have to admit I never saw the package. I would of done it myself, but at the time I had absolutely no time and couldn't do without my vehicle.
Old Dec 8, 2010 | 01:40 PM
harrisqa's Avatar
harrisqa
Does TimeSert work on previous Heli repair failure
Old Dec 8, 2010 | 04:36 PM
mudder1_2000
I believe they have a repair kit called big-sert that does. Check there web site
Skygrasper
Jun 28, 2017 06:10 PM
SteevenH
1997 - 2003 F150
May 27, 2017 01:32 PM
st8yd
1997 - 2003 F150
Oct 22, 2016 12:28 AM
C Milk
Aug 7, 2016 08:46 PM
officespace2
Dec 30, 2015 10:45 AM
