Cold weather start issue
Old Dec 8, 2010 | 11:30 AM
powderdaze's Avatar
powderdaze
So my '97 Expo is having issues starting in cold weather.
Cranks fine and fires up instantly, but the rpm's rev up a bit then it dies before it can idle. After it warms up it idles fine for the most part, sometimes will die at a stoplight, but always fires up again.
Drives perfectly fine when throttled up.
Was going to replace the fuel and air filter tonight. Saw some posts about the Idle Air Control replacement.
Any Ideas on the problem??? Thanks in advance.
Old Dec 8, 2010 | 04:42 PM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
The idel air control valve can usually be cleaned, and it very well could be the problem. You may also have a bad coolant temp sensor. The sensor should set a code.
creeper113
1997 - 2003 F150
Jan 18, 2013 11:59 AM
evopete
May 7, 2011 05:56 PM
raceman3
Dec 23, 2008 10:17 AM
badboyblue
Modular V8 (4.6L, 5.4L)
Jan 3, 2003 01:21 AM
Jay916
Mar 6, 2002 08:08 PM
