Fuel pump reset switch?
Old Dec 1, 2008 | 04:50 PM
Dasvigo's Avatar
Dasvigo
Question Fuel pump reset switch?
I just replaced my dash bezel. The one I put on it had a fuel tank selector switch. Now I am unable to switch tanks. Could this fuel pump reset switch fix my problem? If so where would I find this switch on a 92 F350?
Old Dec 1, 2008 | 04:54 PM
quicklook2's Avatar
quicklook2
92+ has it behind pass. kick panel.
did it switch tanks before?
i would think it had something to do with connection or bad switch.
not real clear on what you did.
Old Dec 1, 2008 | 04:56 PM
truckeradg86's Avatar
truckeradg86
??? try a google search ithought the van's only had double tanks
Old Dec 1, 2008 | 04:58 PM
EPNCSU2006's Avatar
EPNCSU2006
No, the full size trucks had dual tanks as an option from about '80-'96, '97 in the heavy duty trucks.
Old Dec 1, 2008 | 06:03 PM
Dasvigo's Avatar
Dasvigo
Ya I could switch tanks before replacing the switch. I was just hoping it wasn't the switch seeing as how the guy I bought the dash/gauge bezel from did a little price gouching saying the switch is hard to come by and blah blah blah. I guess Ill have to put the old switch back on and see if I can switch tanks again. Problem with the old switch is the tabs/plastic brackets things that attach to the back of the dash bezel are broke off and I would have no way to attach the switch without jerry rigging something which is what I was trying to avoid.
Old Dec 1, 2008 | 07:49 PM
Dasvigo's Avatar
Dasvigo
I didn't find the switch on the passenger side. The tanks and fuel lines are on the driverside so is it possible the reset switch is someplace else?
Old Dec 1, 2008 | 08:22 PM
quicklook2's Avatar
quicklook2
behind the passenger side kick panel.
you need to take it off.
it is there.
Old Dec 1, 2008 | 08:48 PM
924x2150's Avatar
924x2150
prolly bad fuel tank switch or busted wire. The reset, kills the fuel pump completely. I have dual tanks, and nothing pumps once the reset switch is popped up. If truck is running reset is fine. get in pass side swing your right foot up to the bend in the floor and move ur foot to right and "Kick". that cover must be removed completely. it is not a 1 inch round plug or anything like that. It is a 16 x 12 inch piece of molded colored plastic.
Those fuel selectors were junk...I replaced mine long time ago, I hope u didn't get sold a bad used one.
Old Dec 1, 2008 | 10:16 PM
Dasvigo's Avatar
Dasvigo
Very informative thanks, what are some places or websites I can find a new or aftermarket fuel tank switch?
Old Dec 1, 2008 | 11:02 PM
quicklook2's Avatar
quicklook2
i would identify the problem before throwing parts at it.
Old Dec 2, 2008 | 01:10 PM
Dasvigo's Avatar
Dasvigo
I'm going to hook the old switch back up later today. If it changes tanks then I'm going to try to get a new switch. If it doesNT switch tanks then I'm going to inspect whatever wires I can find that may have to do with it. If I cant find something wrong with the wiring then what else should I try or look at?
scaryracer33
Aerostar
Jul 23, 2006 10:08 PM
Traderjoe28
Oct 17, 2004 04:16 PM
gov2mod
1978 - 1996 Big Bronco
Aug 27, 2004 04:49 PM
88xlt
Bronco II
Nov 24, 2003 05:30 PM
crank
Aerostar
Nov 6, 2003 01:15 AM
