I am trying to find the fuel inertia switch or a way to reset everything on my vehicle. If you know of anything thing please im me or post reply. The sooner the better, thank you.
"To reset the inertia shutoff switch, access the switch at the right front kick panel and press and hold the button at the top of the switch. Continue to hold the reset button until it locks in place."
HI there,
In mine (89') the inertia switch is located at the passenger side kick panel and I think all of them are in the same place. You need to remove it off of the mount and dissconnect the wire connector, then turn the van on and let it run out of fuel so you can work on the fuel system.
After you have completed the work hook up the wire connector to the switch and reinstall it to the kick panel and (very important ) depress the button on top of the switch to reset it and your done. Hope this helps.
