Horn Circuit Behind Steering Wheel?
Old May 14, 2019 | 06:05 AM
Mark8man's Avatar
Mark8man
I know this should be simple but can someone explain the horn circuit under the steering wheel. I know the spring loaded brass pin rests on the metal racetrack on the wheel which connects to horn pad but what allows it to complete circuit from there. If I connect a jumper from the brass spring pin to the metal mount on the signal switch (secured with 3 screws) the horn will work. I can't see how the wheel would contact that metal plate to complete circuit. Seems like maybe I'm missing a part? Couldn't find a close up illustration of this circuit in the wheel. Thanks!
Old May 14, 2019 | 08:01 AM
440 sixpack's Avatar
440 sixpack
All the horn switch does is ground the horn relay , through the turn signal switch harness .
Old May 15, 2019 | 12:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No 1978/79 F100/350, Bronco and Econoline has a horn relay unless it has factory installed Speed Control.
With Speed Control, the horn relay attaches to the Speed Control amplifier, located adjacent to the steering column inside the cab.
Old May 15, 2019 | 05:42 AM
Mark8man's Avatar
Mark8man
Thanks Guys. With confirmation from 440 sixpack last evening I determined the steering shaft is not grounded. The column housing is. After I connected a jumper from the shaft to engine the horn worked. I'd think it should be grounded through the steering box slip joint but its not. Hmmm. Anyone deal with this before? The u-joint on steering shaft has continuity so no problem there.
Old May 16, 2019 | 10:37 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, that's a common problem. You need to fabricate a jumper wire for the rag joint.
NOTE: I see you have a highboy. Not sure this is applicable.
Old May 17, 2019 | 08:04 AM
Mark8man's Avatar
Mark8man
Yea, no rag joint on the 77 high boy but I will do some continuity checks. Maybe if I'm losing the ground from the steering box slip coupler to the shaft maybe I can attach a ground strap between it and the shaft. Other possibility is losing the ground at the u-joint but initial check indicated there is good continuity through the joint.
jamesg139
Jun 3, 2014 04:00 PM
Duckmang
Jul 28, 2013 11:40 PM
Bill Hanson
1978 - 1996 Big Bronco
Oct 20, 2005 04:03 PM
John Thomas II
Oct 12, 2005 03:13 PM
Josh79
Aug 4, 2004 08:58 AM
