Help with Horn Contact
Old Jul 28, 2013 | 05:59 PM
Duckmang's Avatar
Duckmang
I've been working on my turn signal switch and additionally my horn. Its the horn I'm confronted with. I have the horn contact under the steering wheel powered up and grounding it clicks the horn relay. I have an aftermarket steering wheel. It has a wire coming up from the horn contact plate that clips into the horn button. The horn contact makes a good connection with the contact plate. If I ground the wire going to the horn switch, I also click the horn relay.
My problem is that the steering shaft isn't grounded. My horn button wants an additional connection to ground but there is none available through the steering shaft. How does the factory horn work with the single contact and no ground through the steering shaft?
Old Jul 28, 2013 | 06:04 PM
HIO Silver's Avatar
HIO Silver
The OEM steering wheel has a brush block whereas aftermarkets do not. You'll need to install a jumper wire over the rag joint to ground the steering shaft. Use two big eyelets (yellow) and a short section of wire to bridge the electrical gap.
After that... toot your horn!!
Old Jul 28, 2013 | 07:04 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's how I ran my jumper.
Old Jul 28, 2013 | 11:22 PM
Duckmang's Avatar
Duckmang
Thanks for the tips guys. I don't have a rag joint but was able to confirm that my steering U-joint is the culprit. In order to make life difficult the downhill side of the joint has no bolt to put a contact under. I'm thinking I will take a piece of stainless tig wire and attach one end under the clamp bolt, bend it in a zig-zag, and clamp it to the shaft on the other end. Won't be pretty but should work.
Old Jul 28, 2013 | 11:40 PM
montana_highboy's Avatar
montana_highboy
Your truck (f250 4x4?) has a U-joint, as you noticed.
Green72F250
Jun 26, 2014 02:40 PM
boaterbob
Dec 4, 2010 07:07 PM
frigerator
May 24, 2009 06:16 PM
Dlobacz
26
Sep 8, 2007 08:28 PM
blk964xbronc
13
Jan 3, 2005 03:04 PM
