1978 - 1996 Big Bronco
Silent Horn, HELP!
Old Apr 19, 2005 | 06:09 AM
Bill Hanson's Avatar
Bill Hanson
Silent Horn, HELP!
I have a 1994 Bronco in very good condition. The horn stopped working. The speed control stopped working as well. I have checked all the fuses which appear to be fine.There are 13 pages of wireing diagrams in my Haynes repair manuel. Could the problem be in the steering column since both the horn & speed control operate from the steering wheel? Any suggestions would be appreciated. Bill.
Old Apr 19, 2005 | 03:57 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Check for power at the horns, while somebody pushes it.
Old Apr 19, 2005 | 07:10 PM
greystreak92's Avatar
greystreak92
Clock spring in the steering column under the wheel. If you lost everything electrical in the steering wheel, this is most likely the problem.
Old Apr 20, 2005 | 09:48 AM
JasonBrod's Avatar
JasonBrod
It could also be the horn relay. The relay should be located on the fuse box. The horn also sometimes is wired throught your light switch.
Old Apr 27, 2005 | 04:19 AM
Bill Hanson
Thanks "BroncoRoadKill", "greystreak92" ,& "JasonBrod" for your suggestions. I used them all, eventually changing the clock spring. My horn is no longer silent & I have speed control again. Thanks again, Bill.
Old Oct 18, 2005 | 07:00 PM
pj1268's Avatar
pj1268
Hi Mr. Hanson...just wondering...when this happened, did you overdrive light start flashing at all?...adversely affecting the way it shifted? ...my horn died and my Overdrive light started flashing at the same time...wondering if i have the same problem with the clockspring....also, was there anything noticeable with the clockspring indicating it was bad? ...hope to hear from you, thanks!
Old Oct 18, 2005 | 09:29 PM
Bill Hanson
silent horn
I lost my horn and cruise control. Had no problems with the overdrive or the overdrive light flashing. The new clock spring solved the problem. It cost me over $300.00 to have it replaced at the local Ford dealership. Bill.
Old Oct 18, 2005 | 10:16 PM
b4hntn's Avatar
b4hntn
Clock spring
Did you see this? https://www.ford-trucks.com/forums/showthread.php?t=404146&goto=newpost
Old Oct 19, 2005 | 11:19 AM
JasonBrod's Avatar
JasonBrod
Do all steering columns have a clock spring? Because I am thinking this maybe the problem with my horn.
Old Oct 20, 2005 | 02:01 PM
Bill Hanson
silent horn
By all means, check your horn first. Don't know when they first started using clock springs. Bill.
Old Oct 20, 2005 | 04:03 PM
lifted88bronco's Avatar
lifted88bronco
good advice bill i replaced my horn relay only to find out it was both of my horns had some sort of insect bird spider etc. living in them ha needless to say they were relocated to the ghetto aka the trash can
