At what milage did you guys decide to change or to full synthetic?
Once you have gone full SYN, have you seen any changes? (Milage, longer runs between changes, quite, etc)?
I have just under 15K on mine right now and almost ready for a oil change. I haven't decided to swop over yet or not. Will start towing the 5er for the spring summer soon so I need to make a decision really soon.
I also just checked with the local dealer on pricing for the 1 gallon jugs of Motorcraft 5w-40 full SYN. $54.71 a jug. I know I can run other brands. I was just posting prices for others to see.
5W40 all year. I buy it on sale and take it to the dealer. They charge for filter and labor.
No reason to run 15w40 just because we used to; things have changed over the years.
I switched at my 5000 mile oil change and now change it when the OLM tells me to.
I switched to Rotella T6 at 50,000. I ran Motorcraft 15w-40 before that. I should have switched sooner, I just didn't. I run it about 7,000 miles. If I ever get a new truck, I'll probably switch as soon as the factory fill is dumped.
Why do you prefer T6 over Motorcraft oil? Or is it the weight your prefer?
I haven't done anything yet. I bought MC 10/30 SDDO from Wally tonight for just under $18.00 a gallon jug. I know it's the standard oil but I'm figuring I'll have another oil change before i start towing the 5er through the mountains during the heat of the summer. I'll probably switch over to SYN then.
I've noticed on some folks switch between SYN and standard. I though once you change over to full SYN you shouldn't change back and fourth? Is this true?
I can see good reasons to change over to T6 though. I've seen T6 ****ting on the shelf in a lot of places but I can't say that about MC.
No it isn't. Your engine doesn't care and it'll hurt nothing.
The primary reason I switched was I wanted to use full synthetic, the motorcraft oil I was using was not. I could not find full synthetic motorcraft diesel oil locally. I selected T6 because of various recommendations here by members over the years. For the southern states, 15w-40 is typically fine which is probably true for TX as well, except for the rare multiple days below freezing and single digits like in 2014. At least with 5w-40 I don't have to think about it but weight doesn't add much to the decision for this area.
