High Idle Mod
Old Oct 28, 2015 | 06:56 AM
Nipperdog's Avatar
Nipperdog
High Idle Mod
I just bought a new 2016 6.7, and would like to do a High Idle Mod.
I did it on my 2011, and am wondering if the procedure and Wiring Color Codes are the same on the 2016 any info would be appreciated.....TNX
Old Oct 28, 2015 | 07:25 AM
SavageNFS's Avatar
SavageNFS
https://www.ford-trucks.com/forums/1...ml#post9494561
Old Oct 28, 2015 | 07:34 AM
Nipperdog's Avatar
Nipperdog
Thanks: That is the Diagram that I used to wire my 2011.
I'm trying to find out if the 2016 uses the same color codes.
Old Oct 28, 2015 | 08:00 AM
SavageNFS's Avatar
SavageNFS
As far as I know they are the same. I'd try it and see if it works.
Old Oct 28, 2015 | 08:19 AM
Just Strokin's Avatar
Just Strokin
From Ford 2016 Service DVD dated, Oct 2015
Old Oct 28, 2015 | 08:31 AM
Nipperdog's Avatar
Nipperdog
Thanks Larry
Old Jan 24, 2019 | 07:34 PM
Diesel_Brad's Avatar
Diesel_Brad
I know this is an old thread but I am having issues
2016 F550
The dam thing has a auto shut down timer and to keep it running and to prevent wet stacking I did the high idle mod
Bought some 20k resistors
found the winging under dash by e-brake
spliced the Brown wire for up fitter switch #4 to the yellow/green wire
then put PTO RPM green wire to PTO reference white/brown with 20k resistor
Truck is up to operating temp, e-brake on and up fitter switch 4 on.
NOTHING. I can hear a relay click but nothing.
Checked fuse for the switch(15 amp #2 position at passenger kick panel) it is good.
Any suggestions?
Old Jan 24, 2019 | 08:16 PM
Just Strokin
Check to see if you wired it up like this post says to connect....
https://www.ford-trucks.com/forums/1...ml#post9504402
Old Jan 25, 2019 | 05:22 PM
Diesel_Brad
Yup, that was the thread I followed
Old Feb 3, 2019 | 10:24 AM
insolution's Avatar
insolution
SEIC Idle Mod with Selectable RPM Switch
Thanks to the brave work of others, I did the high idle mod on my 2013 Super Duty Lariat 6.7L Diesel. Thank you to the earlier posters.
Instead of a single on-off switch, I incorporated a double pole, 4 position rotary switch so I could choose the idle speed I want. In my case, 900 RPM for extended idling, 1200 for a little more and 1800 for jump starting/boosting another vehicle.
Note that this schematic is for diesels only. The gas engine wiring is different. Reference the Ford Body Builder Book for the tech document Q-180R2 for the full scoop.
The switch provides more RPM options than a simple on-off switch some others have used. A red flashing LED shows that the circuit is active. I used a 2 amp fuse to protect the PCM circuit.
FWIW, here is the schematic, which should be good for at least 2011-2015 diesel trucks. I am not sure about the 2016+ models as far as the color coding goes. Someone else can chime in on that. For the 2011, note that CDC64 (shown as WHI/BLU in the schematic) is YEL/ORA in the early 2011 builds.
See the attached PDF for better detail. For some reason the png file looks fuzzy.
Scott
SEIC Idle Mod, 2012-2015 MY 6.7L Super Duty
File Type: pdf
Old Mar 10, 2019 | 07:37 PM
Diesel_Brad
So nobody have any more info on why this will not work?
f350ranchand
Nov 11, 2012 07:26 PM
kenlippold
Jan 14, 2011 09:39 AM
Fire Rooster
Nov 23, 2009 07:09 AM
jamie7375
Jun 13, 2009 09:27 PM
muddy4x4
6.4L Power Stroke Diesel
Aug 1, 2007 12:16 PM
