Fuel filter questions
Old Jul 7, 2015 | 05:51 PM
StanleyZ's Avatar
StanleyZ
For the whole back story see my thread from 7/04. I picked up my parts in Gallup NM today. Gurly Ford, they were great. Maybe not as great as Todd Gurley the UGA running back who will debut in the NFL this year. Take himn your fantasy team. Oh yeah my truck. They convinced me I didn't need the whole filter housing only the WIC sender (see picture). The parts lady was very knowledgeable so I went for it. Would have bought both but the price was pretty high and I really don't think I need it. However, I have studied mine hard and I honestly cant tell on the truck if it unscrews or not. The connector end fits fine.
My more pressing problem is that I cant get the drain to stop running. I just drained a quart and a half and it was still running. Had the front wheels on 2x6 blocks. I'm in an RV park so I can't do too much. This is my 3rd truck and I've done this dozens of times and not had this problem.
Does anyone know for sure that my WIF connector should unscrew (2014 truck)
Any suggestions on why my drain won't stop.
Thanks for the help.
Old Jul 7, 2015 | 05:56 PM
Hopeless Diamond's Avatar
Hopeless Diamond
You need to unscrew the filter housing a few turns to close an internal valve in the filter housing, otherwise you will empty the tank, eventually.
Old Jul 7, 2015 | 06:02 PM
Just Strokin's Avatar
Just Strokin
Yes, the WIF does unscrew.
Per Ford Service DVD
Fuel Conditioning Module Mounted Filter (frame mounted filter)
Disconnect the water in fuel sensor electrical connector.
NOTE: There is a check valve in the fuel conditioning module, that will stop the fuel from siphoning out of the tank. It works when the filter cover is loosened 3 full turns or removed.
Depending on the amount of the O-ring seal swelling, removal of the fuel filter cover may be noisy and require some effort.
Loosen the fuel filter cover and unscrew it counterclockwise 3 full turns.
To install, tighten the filter cover until it contacts the mechanical stops.
Loosen the drain plug until the O-ring is showing and drain the fuel into a suitable container.
Tighten by hand once the fuel has drained.
Remove the fuel filter cover and fuel filter by turning the cover counterclockwise.
Discard the fuel filter.
Remove and discard the fuel filter cover O-ring seal.
NOTE: Apply clean engine oil to the new O-ring seals prior to installation.
To install, reverse the removal procedure.
Install new O-ring seals.
Old Jul 7, 2015 | 06:14 PM
CarlT100's Avatar
CarlT100
Good post, Larry. I tried to rep you; but ... You know the drill.
Old Jul 7, 2015 | 07:00 PM
StanleyZ's Avatar
StanleyZ
OK, thank you both very much. Loosen first, then drain. Why do I feel like Im gonna get a shower? I don't remember doing that at the 10K filter change but I'll sure give it a try. Thanks again.
Old Jul 7, 2015 | 07:27 PM
kper05's Avatar
kper05
Yep, 3 turns then drain. You will only have a few drops, if that. No fuel shower with this design.
Old Jul 7, 2015 | 08:43 PM
jonrjen's Avatar
jonrjen
Got ya covered, Rep sent.
Old Jul 9, 2015 | 10:57 AM
StanleyZ's Avatar
StanleyZ
Just to close this out, I'll say thanks again to all 3 responders. I did the change this AM right in the RV park. Waited until the last morning in case they didn't like it and asked me to leave. It was just as y'all said, turned first, 3 full turns, then drained. Did not spill a drop. This proves once more that FTE is a great resource for anyone owning a Ford truck. It also proves once more that my usual advice RTFI (read the effen instructions) is still good. Thanks again. Stan
Old Jul 13, 2015 | 01:47 PM
porthole's Avatar
porthole
This what I keep in the truck. Used for on the road changes if needed and for my regular maintenance.
The plastic tool box works double as a place to store wet diesel stuff if I have to do a on the road change.
My "cap" is kept with the drain and WIF sensor in so that I can simply change out the filter and cap, clean the cap later.
The filters fit in the plastic coffee cans and I have gallon zip lock bags and a trash bag as well.
Old Jul 13, 2015 | 02:32 PM
Dakster's Avatar
Dakster
I repped him for ya Carl.
And I repped Duane, I like that idea. I used rubbermaid containers for the wet diesel stuff. Take up m ore room than your way.
Glad you got it figured out StanleyZ... and got her fixed and back on the road too!
Old Jul 13, 2015 | 06:07 PM
CarlT100's Avatar
CarlT100
Thanks, Dak, and I also repped Duane for that idea. I will save some coffee cans.
Duane, I like that and I'm going to adopt it.
DieselVol
May 31, 2013 08:41 AM
Flying Finn
31
Mar 23, 2008 08:19 PM
Headviking
Jan 28, 2008 07:05 PM
fastg60
15
Jun 20, 2006 01:29 PM
Rackpatrol
Nov 1, 2004 08:25 PM
