Fuel filter changing
Old Oct 24, 2004 | 10:51 AM
Rackpatrol's Avatar
Rackpatrol
I would like to change the fuel filter on my 2000 7.3 PSD my self. are there any Tips , Tricks or Things to Watch Out for.
Old Oct 24, 2004 | 01:00 PM
Pikachu's Avatar
Pikachu
Its pretty straightforward. Unscrew the cover, yank old filter, replace gaskets/o-rings, replace cover. Cycle the ignition a couple times to fill the fuel bowl, then start it. Might run rough and smoke, but should clear up in a minute or two.
Old Oct 24, 2004 | 01:42 PM
DALPILOT's Avatar
DALPILOT
Make sure the bevel on the cover gasket is set in the correct direction. Observe it carefully as you remove the old one and replace with a new one in like direction. Make sure the O ring on the filter does not come out of it's groove as you slide it into the bowl. A little diesel on it will lubricate it sufficiently to insure that does not happen.
Old Oct 24, 2004 | 03:24 PM
RedTaurus94's Avatar
RedTaurus94
Might want to drain the fuel filter bowl beofre opening it up. Might be less messy that way. There are a variety of ways to remove that lid. A strap wrench might work, but I know a pair of channel locks works pretty well, or they even make a special wrench to fit it that can be purchased, it you so desire. Also, some filters come with the cover and the filter itself made together. If you have one of those, you'll need to get another one just like it, or get yourself a replacement lid, if you don't already have one.........
Old Oct 24, 2004 | 03:36 PM
troutnut1's Avatar
troutnut1
Don't do what I did once and forget to allow the fuel bowl to fill before checking for leaks. I looked for leaks immediately after starting the engine and everything looked good. But 70 miles later when we stopped at Costco I noticed I was leaving a substantial trail of diesel. Embarrassing! Removed the cover and put it back on again and everything was fine.
Old Oct 24, 2004 | 10:06 PM
BigRed350's Avatar
BigRed350
[QUOTE=DALPILOT]Make sure the bevel on the cover gasket is set in the correct direction. Observe it carefully as you remove the old one and replace with a new one in like direction. QUOTE]
In case you don't notice which direction the beveled O ring was in, the sharp point of the bevel is UP! It looks backwards this way, but that's the way it goes. The directions I've seen don't seem to tell you which direction to put it, but it will leak if installed upside down.
Old Oct 25, 2004 | 06:17 PM
RedTaurus94
The Motorcraft and Racor filters have pretty clear instuctions as to how to install the O-ring.........
Old Oct 25, 2004 | 06:45 PM
RedStroker6's Avatar
RedStroker6
if there is a Baldwin filter dealer near you just go there and ask for the respective fuel filter for your truck and it comes with the cap on it and all. just get the old one out and stick the new one in. tightens down with a spot on top and center for a 1/2 in. socket. took me like 3 minutes
Old Nov 1, 2004 | 05:56 PM
Rackpatrol's Avatar
Rackpatrol
Thanks for all of the help. I will give it a try.
Old Nov 1, 2004 | 08:25 PM
Frobozz's Avatar
Frobozz
If you buy that style, by all means SAVE THE OLD CAP IN THE TRUCK!!!!(I can't state that clearly enough...) If you're on the road somewhere and the filter gets clogged and all you can get your hands on is a stock filter (like, say, at a Ford dealer), there is no way to put it on the Baldwin cap. You *must* have a stock cap for a stock filter, and new ones from the dealer are a pretty penny. (Which is why I buy the Racor filters and avoid the Baldwin ones, but whichever way you go, you should always have a stock cap with you in the truck.)
Duncan
