codes 632 and 628
Old Oct 7, 2013 | 04:53 PM
Archuriel's Avatar
Archuriel
codes 632 and 628
I started a thread in the wrong place here https://www.ford-trucks.com/forums/1...l#post13580672.
I was directed here to get help.
I have a 4.9 i6 300 1994 getting these codes 632 and 628 It runs rough- sputtering when the overdrive is on. No pulling power. I was hoping someone would point me in the direction I need to go to get this fixed.
Thanks.
Old Oct 8, 2013 | 07:10 AM
rla2005's Avatar
rla2005
Code 632 (KOER): E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
Did you cycle the OD switch at the proper time?
Code 628 (CM): Excessive torque converter clutch slippage
Since this code is historical (Continuous Memory) it has occurred sometime in the past. I would suggest you clear the codes, drive the truck for a few days then recheck. If it comes back again then you may have a bad torque converter.
Have you checked the fluid level? What color is the fluid? Has the fluid been changed recently?
Old Oct 8, 2013 | 08:25 AM
Archuriel's Avatar
Archuriel
Thanks for responding. I am used to doing the self test on my manual tranny. So I have to hit the OD button after the 3 flashes for the 6 cylinders? I will read up on it and retest and check the other things you pointed out and get back. Thanks.
strokinout
28
Oct 25, 2013 09:59 AM
LSO1123
23
Aug 5, 2011 11:50 AM
SALVY
Mar 19, 2009 09:31 AM
iowastroker
Feb 13, 2009 02:14 PM
motoman
Feb 20, 2007 09:12 PM
