Overdrive problems
Old Sep 30, 2013 | 03:45 PM
Archuriel's Avatar
Archuriel
Overdrive problems
94 I6 300 4.9 runs rough when the overdrive is on. It sputters and loses power. I ran codes and got 632 KOER and then 628 KOEO.
Can anyone help with this? Thanks
Old Oct 7, 2013 | 12:58 PM
Archuriel's Avatar
Archuriel
Nobody knows this one?
Well I hope someone out there has a little knowledge in this area because I sure don't know where to start.
Old Oct 7, 2013 | 01:27 PM
timbersteel's Avatar
timbersteel
I can't offer any help..sorry. Perhaps another member will chime in with help. May also try pm'img Mark Kovalsky. He's the transmission guru. May also try posting in the Clutch, differential, transmission forum.
Old Oct 7, 2013 | 01:33 PM
85e150's Avatar
85e150
I don't know much but I know this:
Ford Check Engine light Codes
Short answer:
<table border="1" width="87%" align="center"><tbody><tr><td>
632
</td><td>
(R)
</td><td>
E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
</td></tr></tbody></table>
628
</td><td>
(M)
</td><td>
Excessive converter clutch slippage - Transmissions
Old Oct 7, 2013 | 04:45 PM
Archuriel's Avatar
Archuriel
Short answer:
632
</td><td>
(R)
</td><td>
628
</td><td>
(M)
</td><td>
Thank you both. I didn't realize there was a transmission forum.
kstatechris
2004 - 2008 F150
Aug 22, 2012 09:30 PM
Grubbworm
Apr 21, 2011 09:56 PM
Grubbworm
Apr 21, 2011 12:35 PM
