Power door lock switch
Anyone know where to get a power door lock switch to fit a 2000 model? The one that sits on the interior driver door panel to lock/unlock all the doors. Or anyone ever taken the switch apart and repaired it? The switch changed in 02. I can find those, but not the earlier ones.
Should be easy to find. There are several on Ebay. Click below.
Ford Mustang Power Door Lock Switch New OEM Part F4ZZ 14028 B Right RH | eBay
Oops, I think that was the wrong one. Try these.
BRAND NEW FORD LINCOLN OEM RH FRONT DOOR LOCK SWITCH #XL1Z-14028-AB | eBay
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Well it appears the points are worn inside the switch. And the parts are too small, and too hard to get at (and too hard to see) to file them down. I did realize that the lower half of the switches (driver side and passenger) are the same, so I pulled the driver side button off the bad switch and put it on the passenger side lower half of the working switch.
Now I have a functioning driver side lock / unlock switch with the letters that face the right direction, and a non-functioning passenger side lock / unlock switch. Not the perfect solution, but it works until I can find a replacement switch.
Found switches for 2000-2001 Super Duty
As of December 2014, I was able to find several listings on eBay for replacement door lock switches for between $12 (remanufactured) and $45 (new) each.
Driver (left) part number (brown switch base, "L/U"): XL1Z14028AA
Passenger (right) part number (black switch base, "U/L"): YL3Y14028AB
I got a 'remanufactured' switch, so I'll report back after a while to see if it lasts.
williamm3267
05-23-2010 05:59 PM
Mr. Hatt
1997-2006 Expedition & Navigator
02-15-2010 03:37 PM
curbthrasher
03-27-2008 09:32 PM
