Truck looses power while driving
Old Mar 30, 2005 | 10:31 AM
51dueller's Avatar
51dueller
Our '78 F-250 supercab, 400 cid, motorcraft 2 barrel will loose power when driving. You'll be going along and the truck will not respond to the accelerator pedal. If you shift to neutral the truck is barely running (idle) and when you try to give it gas it dies. We've replaced the fuel filters and fuel pump. The fuel pump cured it for a while but it's now doing it again. Any help is appreciated.
Old Mar 30, 2005 | 01:01 PM
smoke n tires's Avatar
smoke n tires
i would get some info on checking the float levels on you model carb. you maybe better off rebuilding it and adjusting it from scratch. also check the choke operation.
Old Mar 30, 2005 | 01:10 PM
yeha4x4's Avatar
yeha4x4
I'd go with smoke n tires on that. Choke may be closing.
Old Mar 30, 2005 | 08:12 PM
51dueller's Avatar
51dueller
It's not the choke. Once it dies, it will fire on a turn of the key and drives normally again.
Old Mar 30, 2005 | 10:44 PM
LxMan1's Avatar
LxMan1
Sounds like a failing pick-up coil in the distributor. They will make it act like it's out of fuel, then restart and run ok.
bradshaw6243
Jul 27, 2011 03:46 PM
tomtek
May 12, 2010 10:40 AM
mightypuppetmaster
Bronco II
Oct 29, 2007 12:14 PM
steviebam
Oct 3, 2006 09:54 AM
Saxon
Jul 24, 2003 05:07 PM
