more cfm from 850
Old Mar 28, 2005 | 12:20 PM
Ol Buster's Avatar
Ol Buster
more cfm from 850
Hello, I got a 850 holley chokeless carb. I was wondering if there is any way to get the cfm's up to a 1000 or 1050? If anyone has done this, would I be better off to get a different carb or rebuild?
Old Mar 28, 2005 | 06:23 PM
TRaGiK's Avatar
TRaGiK
First, why? You would have to have a mightly wild 460 or bigger to come even close to needing anywhere in the neighborhood of 1000cfm. You'd likely have to be making around 750hp or more to need it. My boss ran in King of The Street (succesfuly with a mid 8 second Cuda) and only ran about an 1100 cfm dominator.
Ok, so to answer your question, buy a different carb. Get a Holley dominator. I believe they come in sizes from 750 to around 1300 cfm. Stay away from Demon carbs as the car i mentioned above actually slowed down 1 - 2 tenths with a demon.
Old Mar 28, 2005 | 10:28 PM
LxMan1's Avatar
LxMan1
I'd doubt that you will gain that much. You are limited by the venturi size and the size of the throttle plates in the base plates. You might be able to bore out the upper veturies a little bit, but you must do them the same or it will be unbalanced.
Old Mar 28, 2005 | 11:57 PM
Ol Buster's Avatar
Ol Buster
Thanks for the info, my motor is a 501. The compression is a tick above 12 to 1. I am running a pretty healthy cam. Sled pulling is the name of the game.
Old Mar 29, 2005 | 04:15 AM
Ford_Six's Avatar
Ford_Six
Something like that you may be better off with a dual 750 setup, if that's legal in your class. Not really any worrying about driveability suffering, I don't think your sled truck is your daily driver!
Old Mar 29, 2005 | 06:59 PM
TRaGiK's Avatar
TRaGiK
I think dual 750's would be a bit much for anything.
Go with a dominator 1000.
Old Mar 29, 2005 | 09:23 PM
LxMan1's Avatar
LxMan1
I think Holley makes a 950cfm 4150 series carb if Dominators are not legal.
Old Mar 30, 2005 | 11:33 PM
There Goes The Neighborhood's Avatar
They also make a 1000 CFM 4150. From all tests I've seen, the 1000 idles better, transitions better, and makes more power than a 950. It seems as though holley did better homework with the 1000, and eliminated all the "Big Carb" problems that plagued the 950. It's only a few dollars more, why save $20 to get a much more inferior product?
Tomahawk
Jul 10, 2014 01:03 AM
fordman1986xlt
Feb 21, 2013 06:37 PM
Boss Machine
Aug 16, 2008 10:08 PM
backwoodspuller
19
Sep 30, 2006 09:30 PM
The Tree
Jun 8, 2004 11:18 PM
