Coolant Temp Readings
Old Oct 10, 2010 | 12:23 PM
Strokin-8's Avatar
Strokin-8
For those that are reading coolant temps, What are you using and if you are using gauges wher did you place the temp sender?
Old Oct 10, 2010 | 12:52 PM
69cj's Avatar
69cj
ScanGauge ll. It plugs into OBD port and reads a multitude of functions for a $159 @ AZ.
Old Oct 10, 2010 | 03:30 PM
mohle's Avatar
mohle
Original Edge Evolution. It's a tuner, but I use it just for gauges - same as the Edge Insight. Plugs into the OBDII port.
Old Oct 10, 2010 | 04:07 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I use the UltraGauge - they had a sale on it a couple of months ago....50 bucks with a 10 buck rebate. It has other gauges on it, but for 40 bucks, just to have the coolant temp is worth it. It too, plugs into the OBD port.
Old Oct 10, 2010 | 05:53 PM
Strokin-8's Avatar
Strokin-8
I have autometer electric gauges and have checked the ones I can check against the sct in data log mode. I see a difference in boost and in coolant temp. Boost is read at elbow and coolant is checked at block.This might explain why i see a coolant difference, entering coolant as apposed to block temp. I either need an OBD reader or move some of my sensors to read where the actual sensors are.
Sooper Camper
Nov 30, 2013 09:24 PM
hoytfan99
Apr 7, 2012 07:08 AM
savage250
Feb 1, 2012 10:43 AM
sncbluegt
6.7L Power Stroke Diesel
Dec 15, 2010 10:04 AM
dvfd12
May 18, 2009 11:21 AM
