low temp readings
Old Apr 6, 2012 | 09:57 PM
hoytfan99's Avatar
hoytfan99
low temp readings
so ive been using my new scan guage and my coolant temps are 178-180 after 40-45 minutes of highway driving. Oil temps are fine, so why a low reading.
Old Apr 6, 2012 | 10:22 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
Dont know if you entered a code for coolant but it comes standard on the scanguage listed as fWT if you wanted to check your entered codes reading against the standard one. If that is the standard reading then looks like a thermostat may be in your future. I had mine on a long drive today (about 100 mile one way) and my temps hovered around 198-202 on the low end and would climb up to about 208-210 on the high end before coming back down. Now those readings were taken doing around 70mph on some slight hills but in town when driving is 30-40 mph the temps stay around 192-200. Hope this helps ya out.
Old Apr 6, 2012 | 10:24 PM
ROBBINthaHOOD
Oh and on record my oil temps never climbed over 8 degrees over the coolant.
Old Apr 6, 2012 | 10:52 PM
zhilton's Avatar
zhilton
Like Mark suggested, I'd check to make sure the SG is set-up properly (though the OBd-II should be giving straight numbers like that). Afterwards, if your coolant is still that cool, you more than likely looking at a thermostat replacement. When they fail, they're supposed to fail to the "open" position so that you don't burn the motor up.
Old Apr 7, 2012 | 07:08 AM
hoytfan99's Avatar
hoytfan99
thanks the fwt is the factory reading from scan guage.
Bsentman888
Feb 2, 2013 09:52 AM
Jarhead97
Nov 12, 2012 06:37 AM
billbot
Jul 8, 2012 08:48 PM
john19999
Nov 21, 2010 12:43 PM
brooksbronco17
24
Mar 28, 2010 06:00 PM
