Coolant Temp?
Old May 17, 2009 | 11:45 PM
dvfd12's Avatar
dvfd12
Coolant Temp?
Those of you with aftermarket temp gauges, whats your normal opperating temp?
I just installed one in the side of the water pump and its reading 240 to 250. I use the same gauge for tranny temp (switched) and it is right on with what my programmer shows. Could my sending unit be screwed up?
Old May 17, 2009 | 11:51 PM
RussB's Avatar
RussB
Those temps seem high to me ! We just put a water temp gauge in Ryan's truck.. it reads under 200 and when it hits 203 the thermostat opens and it goes back down ! (i think thats how it works) Your sending unit could be screwed or your temps are just that high !! If they are that high I would make sure your thermostat is working !
Old May 17, 2009 | 11:54 PM
dvfd12's Avatar
dvfd12
Thats what I'm wondering. The factory gauge on the dash just reads normal, about half way up.
Old May 17, 2009 | 11:57 PM
RussB's Avatar
RussB
That one always just reads half way !! POS in my opinion ! Ryan's Ispro moves all over and the stk one stays in the middle !! I think its like an idiot light !! Only moves when its way to hot !!!!
Old May 18, 2009 | 07:37 AM
Ponyboychris's Avatar
Ponyboychris
My temps are about 195 degrees on my aftermarket water temp gauge. Something is not right with yours.
Old May 18, 2009 | 07:39 AM
dvfd12's Avatar
dvfd12
I did use about 2 wraps of thread tape when I put it in. Could it be a ground issue?
Old May 18, 2009 | 08:38 AM
megawatt00's Avatar
megawatt00
Is it 2 wire or single wire guage? If a single wire then the tape may impede the ground.
Old May 18, 2009 | 09:30 AM
dvfd12's Avatar
dvfd12
Single. Would it cause an inaccurate reading, or would it cause erratic movement?
Old May 18, 2009 | 09:37 AM
megawatt00's Avatar
megawatt00
A bad ground could cause either. These sensors run on a milivolts & resistance so any impedement will throw them off. Make sure that the grounds and all other connectios are clean and tight. If it is ok with the trans temp then it is a sending unit issue. clean the ground and check it again.
Old May 18, 2009 | 11:21 AM
stormyrider's Avatar
stormyrider
Remove the teflon fape and try copper based antisieze to help seal the threads. It is conductive and should solve your problem. Clean threads on socket and sensor completely.
snowdog79
Jan 23, 2014 10:28 PM
78 & 87 Super Cab
Jul 6, 2013 11:09 PM
mrad
Aug 13, 2009 04:09 PM
Dragrazor
Electrical Systems/Wiring
28
Nov 17, 2007 10:02 PM
johnsjsj
Sep 18, 2007 10:07 PM
