stuck distributor
Old Oct 9, 2010 | 05:35 AM
77trailerspecial's Avatar
77trailerspecial
stuck distributor
i got bolt loose but cannot turn distributor to adjust timing,i have tried pb blaster and wd40 ,is still froze up ,any ideas?
Old Oct 9, 2010 | 06:16 AM
jim collins's Avatar
jim collins
Happens a lot on these fords. try tapping it, gently, more blaster,more tapping and patiance. It will come out, if you accidently break it ,then get the big hammer out. Then use some no-seize lubricant on it whenyou put it back in. ..........P.S. some guys use heat from a torch, but I never did like that way unless I planned on replacing the dist. In that case then get the BFH.
Old Oct 9, 2010 | 12:04 PM
shortboxd's Avatar
shortboxd
50/50 mix acetone and trans fluid as a penetrant (or Kano Kroil), and use no heat greater than a heat gun (or high-wattage hair dryer). Patience and some time needed here- you're dealing with dissimilar metal corrosion, which is nearly effective as welding the two together....
Old Oct 9, 2010 | 12:07 PM
jfive's Avatar
jfive
there is this tool Blue Craftsman Rubber Strap Pipe Wrench Grip Tool EUC - eBay (item 180566160796 end time Oct-25-10 06:22:20 PDT) mine is not turning either, and as soon as I can find mine I am gonna try it, but I am sure it will work. I have used it on the most stubborn oil filters and stuff.
Old Oct 9, 2010 | 12:49 PM
jim collins
Sometimes you can take an old fan belt and wrap it in such a way it won't slip and use it like the wrench that ' jfive' was talking about.I never was able to make it work. Lube and patience is what it takes most of the time .
Old Oct 9, 2010 | 03:47 PM
shortboxd's Avatar
shortboxd
the fanciest of wrenches, pipe, band, chain, belt, rubber strap, etc. aren't going to do a bit of good if you don't break the dissimilar metal corrosion weld. You'll break the distributor casting before it even thinks of turning. BTDT.
Patience, penetrant soak it, patience, heat it a little, soak it, patience, continue as required........
Old Oct 9, 2010 | 07:49 PM
bmuhlbach's Avatar
bmuhlbach
Mine did this to I sprayed tons off pb blaster and a hit with a rubber hammer. now when ever I change the oil I pour a small amount on the block and dist area.
Old Oct 9, 2010 | 09:25 PM
Flat_Ford's Avatar
Flat_Ford
my solution https://www.ford-trucks.com/forums/9...stributor.html
Old Oct 10, 2010 | 06:15 AM
jim collins
I just noticed there is another thread running right now with the same problems and solutions.If you haven't saw it yet,I suggest you take a look at it. JIM
79fordrat
Oct 21, 2012 04:13 PM
64fordf100292
Mar 16, 2007 04:11 PM
mwilbourn
Jan 26, 2005 01:19 PM
nevereverquit
Dec 29, 2003 06:59 PM
