460 distributor problem
Old Dec 29, 2003 | 07:45 AM
nevereverquit's Avatar
nevereverquit
Have a rebuilt 88 model fuel injected 460 with a rebuilt distributor that get so hot it melts the rotor. Paid $3000 for the rebuild-ran 10k miles and knocked distributor gears off twice, found out the bushing was bad in the distributor, bought a rebuilt distributor and the overheating of the distributor started. A shop tried shimming the distributor up off the block but it still has the problems. Any suggestions? I am stumped. Thanks!
Old Dec 29, 2003 | 09:37 AM
fordman428's Avatar
fordman428
post it in the 385 series forumn you will have better luck with replys
Old Dec 29, 2003 | 09:43 AM
Ratsmoker's Avatar
Ratsmoker
Moved to Lima Forum.
Old Dec 29, 2003 | 06:50 PM
airharley's Avatar
airharley
Do you know what kind of cam is installed in the engine? You may have the problem because of the wrong type of material for the distributor gear, steal vs cast iron cam. This is a shot in the dark for me at this point without knowing what kind of cam you are running.
Old Dec 29, 2003 | 06:59 PM
georgedavila's Avatar
georgedavila
All I can think of is alignment of the shaft is somehow off, shearing pins on the original and creating heat in the bushing on the rebuilt distributor. I'd look at the oil pump.
humphrey169
Apr 2, 2017 06:14 PM
richardfine
34
Feb 11, 2017 12:26 AM
gottagojoe
Apr 28, 2011 08:04 PM
obars
Apr 25, 2006 07:09 AM
mike93082
Bronco II
Jan 24, 2006 10:12 PM
