Distributor Identification
Old Jan 26, 2005 | 09:42 AM
mwilbourn's Avatar
mwilbourn
Question Distributor Identification
I need to identify the distributor on my 63 Unibody 223 engine. Where can I find out what the numbers on the distributor tag mean?
Old Jan 26, 2005 | 11:18 AM
barry's Avatar
barry
Post the dist number and I can decipher it for you.
Barry
Old Jan 26, 2005 | 12:23 PM
mwilbourn's Avatar
mwilbourn
lower left corner of the plate - 292
upper right corner - C3TF
lower right corner - D
Old Jan 26, 2005 | 12:56 PM
camperspecial65's Avatar
camperspecial65
from what I have found, it is a 63 223 distributor...the C is a 60s part,3 is 1963,T=truck...dunno bout the F, the D is the suffix letter which from what I have been told is revision level...but my book shows the service replacement dist. is a C3TZ-12127-C. Shows the dist/engine was used in B,F,N & P 100-600 trucks/vans
If Im not correct or you can add anything more to the mix, go ahead Barry....weird why they wouldnt put the dist number itself on it...The family it is in as to part numbering that is...
-cs65
Old Jan 26, 2005 | 01:19 PM
barry's Avatar
barry
THe only time the put the "12127" numbers was when they were cast into the body of the dist. They expected the parts guys to know that the basic is 12127 ( and they should know). Back then they actually serviced them and we had to know or basics, now they just pop a complete unit in. Now all there is inside is a stator wheel and modeule on the outside.
Barry
bubbatay
Jan 5, 2015 05:55 PM
400Nut
Apr 28, 2014 11:27 AM
79fordrat
Oct 21, 2012 04:13 PM
B Dobz
28
Jun 25, 2012 05:46 PM
Canadianice
Bronco II
Feb 20, 2007 01:13 AM
