Is there some kind of glue or something I can use to keep my door weatherstrip up? I took one out of a used truck because I didn't have one at all and I've used a all around spray glue and it keeps fallin back down. The weatherstrip is in good shape just won't stay up. Thanks for the help guys!
3M makes a Weatherstrip Adhesive - traditionally yellow; also comes in black - any auto parts store should carry it. It's in a metal tube about the size of a toothpaste tube.
I've been using the same stuff for years and it holds-up pretty good. You have to remember to let it sit awhile and tack-up before you put the two sides together otherwise you're just wasting your time.
Used both the black and yellow gorilla snot , both worked good
I like to use some spring clamps to hold the rubber to the pinch weld while the glue sets, seems to hold it place pretty good
